Z1000 A1 Wanted
ode lad
Z1000 A1 Wanted
#1 PostAuthor: ode lad » Wed Jul 04, 2018 7:25 am
Hi Guys, lm looking for a Z1000 A1, not Ltd etc to Streetfighter. Early model preferred so Tax excempt. Would like something already registered and running. Thanks Paul ........................
8 Valve Mark
Re: Z1000 A1 Wanted
#2 PostAuthor: 8 Valve Mark » Thu Jul 05, 2018 10:21 pm
why dismiss an ltd? same frame as an a1 but frame numbers slightly different..a1=kzt00a and ltd=kzt00b. I'm not a streetfighter fan personally n think your plan would detract value from the original bike, whereas putting the same energy n money into summit like a cheaper bandit or zephyr might actually add value n cost less to source a donor/victim.if tax exemption is your driving force gs750/1000's are much more available, cheaper n take gsxr usd front ends . good luck either way. mark
Re: Z1000 A1 Wanted
#3 PostAuthor: Ultim8pc » Thu Jul 05, 2018 10:28 pm
8 Valve Mark wrote:why dismiss an ltd? same frame as an a1 but frame numbers slightly different..a1=kzt00a and ltd=kzt00b. I'm not a streetfighter fan personally n think your plan would detract value from the original bike, whereas putting the same energy n money into summit like a cheaper bandit or zephyr might actually add value n cost less to source a donor/victim.. good luck either way. mark
Because getting an original as possible 1000a1 trumps saving money on something that isn't?
On a related note, that's why I have an 1000Ltd B1 for a Sanctuary style restomod. Would be a pity to 'butcher' a nice z900/1000a.
8 Valve Mark
Re: Z1000 A1 Wanted
#4 PostAuthor: 8 Valve Mark » Thu Jul 05, 2018 11:18 pm
i dont get it either. my, 79 mk2 engined ltd (un-ltd) z900 bars, 18"rear wheel, z900 tank n harris 4-1is one of the best riding n handling 8 valvers i have ever owned from a z1a to a unitrack. i am nearly 54 tho so i might be forgetting some!! never streetfightered anything tho :nevertheless an a1. ah the wisdom of the baldy old man!!!
Re: Z1000 A1 Wanted
#5 PostAuthor: Ultim8pc » Fri Jul 06, 2018 9:08 am
In summary, the older Ltd models offer a similar experience, in what is in essence the same bike, but for a lot less money!
Charlie
Re: Z1000 A1 Wanted
#6 PostAuthor: Charlie » Fri Jul 06, 2018 9:36 am
With respect guys, it doesn't matter if anyone else does not "get it". It does not matter about value either. If the OP wants to street fighter a Z1000A1 that's his choice.
Good luck in your search Paul :wink:
ode lad
Re: Z1000 A1 Wanted
#7 PostAuthor: ode lad » Thu Jul 12, 2018 5:16 am
Now sorted thanks to fleabay ......................
Re: Z1000 A1 Wanted
#8 PostAuthor: Ultim8pc » Thu Jul 12, 2018 7:52 am
ode lad wrote:Now sorted thanks to fleabay ......................
Spill the beans then Sir!
