Z650 barrels and/or head
Building a standard Z650 engine. I have the bottom end parts, but need a good set of barrels and pistons. Also a good cylinder head. It is single row cam chain, I could use a early  750 head as long as its drilled for the top roller and has a cable tacho output.
						- AL MARSHALL
Re: Z650 barrels and/or head
hi got loads of z650 engine bits/ also a z750 barrels pistons single row camchain tacho drive in cylinder head  cams /
									Thanks,
John
						John
- 8 Valve Mark
hi, i just noticed the post. I've got a nice z650 cam cover, coils, reg/rectifier i could live without..cheers mark
Sorry for a slow response been overseas for a while. I managed to source most of the bits I need off a local, but will keep i mind what you guys have.
