fuel hose
BigZCas
fuel hose
#1 PostAuthor: BigZCas » Fri Aug 24, 2018 6:53 pm
Could someone advise the correct ID and OD for Z900a4 fuel hose please :??
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: fuel hose
#2 PostAuthor: Philippe » Sat Aug 25, 2018 6:41 am
Hi Cas
in some parts lists the inside diameter is mentioned.
I think it's 6mm inside, someone will correct me if I'm wrong.
Good luck
BigZCas
Re: fuel hose
#3 PostAuthor: BigZCas » Sat Aug 25, 2018 7:11 am
Thank you Philippe
Past 5 Years
1976 KZ1000a1, Red
Re: fuel hose
#4 PostAuthor: Garry.L » Sat Aug 25, 2018 8:19 am
From memory 7mm, but whichever you get try and get some that's ethanol resistant.
I had to replace all the fuel pipe on a H1 recently which was less than a year old. The pipe had shrunk, had gone very brittle and started to split!. :shock:
Re: fuel hose
#5 PostAuthor: Philippe » Sat Aug 25, 2018 10:51 am
Hi Guys
I never use E95 since the amount of ethanol increased to 10%, I allways use Super + 98.
They put ethanol inside because the world leaders think that rabbits are very important !!!
Do their planes fly on ethanol too? :mrgreen:
Kev1R
Re: fuel hose
#6 PostAuthor: Kev1R » Sat Aug 25, 2018 11:13 am
Agree with Philippe - I only fill up bikes with the 'Superunleaded' options - and only the 95 octane regular unleaded when I have no choice.
(although over here the ethanol content is still only 5% I believe)
010
