fuel hose
fuel hose
Could someone advise the correct ID and OD for Z900a4 fuel hose please
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
Re: fuel hose
Hi Cas
in some parts lists the inside diameter is mentioned.
I think it's 6mm inside, someone will correct me if I'm wrong.
Good luck
Good luck
Re: fuel hose
Thank you Philippe
Past 5 Years
1976 KZ1000a1, Red
1976 KZ1000a1, Red
Re: fuel hose
From memory 7mm, but whichever you get try and get some that's ethanol resistant.
I had to replace all the fuel pipe on a H1 recently which was less than a year old. The pipe had shrunk, had gone very brittle and started to split!.
Re: fuel hose
Hi Guys
I never use E95 since the amount of ethanol increased to 10%, I allways use Super + 98.
They put ethanol inside because the world leaders think that rabbits are very important !!!
Do their planes fly on ethanol too?
Re: fuel hose
Agree with Philippe - I only fill up bikes with the 'Superunleaded' options - and only the 95 octane regular unleaded when I have no choice.
(although over here the ethanol content is still only 5% I believe)
010
