Philippe wrote:Hi Cas
open the kill switch, check if the inside is undamaged.
Mind there are little balls and springs inside so don't loose those.
Good luck
DavidZ1R wrote:Think you have the white wires wrong, you should have the white feed from the battery with the double joint, into that goes white/red wire from the fuse box, and the white wire from behind the solonoid into the double joint, the other goes to the white feed wire from the reg / rec, that's how mine goes, no problems
BigZCas wrote:Hello Dave,
You are correct, I tried the same switch on another bike and the same thing happens, the 20amp fuse popped .
And so it is conclusive, the fault is with the kill switch.
Thank you all for your help and suggestions.
ZedHead wrote:BigZCas wrote:Hello Dave,
It was the only logical conclusion Steve.
To follow up on Taffus post, I would lift the electrical plate and check which pins the yellow, pink and blue wires feed on the the white and green connectors. Making sure they correspond with the AC feeds to your reg/rec. On the Z1, the pins are identical for these wires on both connectors but the z900 could be different. The diagrams do not follow any order so offer no help in this respect.
Taffus wrote:ZedHead wrote:BigZCas wrote:Hello Dave,
Might give it go tomorrow if the weather is better (pissing down here!)
The Zpower instructions were correct for the fitment of the reg/rect
