Cylinders 1 & 3 hot header pipes discolouring
markhemstock
#1 PostAuthor: markhemstock » Tue Sep 04, 2018 4:44 pm
Posted not long ago about discoloured down pipes. Since renewed both sets points condenser restored bike but have never touched these it runs much better ticks over better. Checked new plugs and cylinders 1 & 3 plug ceramic around electrode was white 2 & 4 was light brown. Manual states should be light brown so 2 & 4 ok 1 & 3 hot. Was this likely to be a ignition issue or more mixture issue? When I restored the bike I did strip carbs set them as the genuine Kawasaki manual with great care. Manual also states if running hot run on cooler plug 7bes can I put cooler plug in hot cylinders and keep standard plug in cylinders that are ok. YOU NOW TELL Iam no professional engineer lol. Is adjusting the fuel mixture if you think that’s the issue to be left to a pro. CHEERS FOR ANY HELP Mark
Z9A4tfx
Re: Cylinders 1 & 3 hot header pipes discolouring
#2 PostAuthor: PAULJAC47 » Tue Sep 04, 2018 5:37 pm
Mark,get hold of a Gunson colourtune,tells you issues straight away...
#3 PostAuthor: warren3200gt » Tue Sep 04, 2018 6:11 pm
Colour tune as Paul suggests and 7's are hotter than 8's not cooler
#4 PostAuthor: ZedHead » Tue Sep 04, 2018 7:26 pm
+ 2 for colour tune 1 & 3 running too lean
Captain Custard
#5 PostAuthor: Captain Custard » Tue Sep 04, 2018 7:35 pm
Sounds more like your points are incorrectly set for the coil shared by cylinders 1 and 3.
If the gap is incorrectly set the advance can be way off and cause the over heating you're seeing.
Use a dwell meter or multimeter if you have one or I just wire a spare lamp to the points.
Most manuals give guidance on how to set up the dwell angle.
#6 PostAuthor: z1bman » Tue Sep 04, 2018 8:11 pm
Captain Custard wrote:Sounds more like your points are incorrectly set for the coil shared by cylinders 1 and 3.
coils & points are 1+4 & 2+3
Captain Custard
#7 PostAuthor: Captain Custard » Tue Sep 04, 2018 8:33 pm
Sorry! Brain fart due to lack of beer. Miss-read the question.
Users browsing this forum: No registered users and 111 guests
