Z1-R stuff Wanted or Swap.
#1 PostAuthor: Garry.L » Wed Sep 12, 2018 7:10 pm
Looking For the following if anyone can help....
Decent set of Z1/Z000/Z1R engine case covers, ie Clutch, Gennie, Points and front sprocket covers. Or if it helps swap for the full set of powdercoated Black Finned covers in the pic below.
Decent set of front forks, lowers & stanchions.(presume Z1000 A2, Later Z650 etc is the same?.)
A set of Standard or Standard look rear Shocks. Or swap for the piggy-back set in the pic below.
Lastly (for now) and a bit of a long shot, but also looking to reinstate the original front brake set-up on a Z1-R, ie lever perch, cable, master cylinder etc. everything or anything if you can help.
Ta.
Re: Z1-R stuff Wanted or Swap.
#2 PostAuthor: paul doran » Wed Sep 12, 2018 7:50 pm
I have points sprocket and clutch cover
I also have some of the front brake bits like lever and mechanism down to splitter I also have a master cylinder but no cap
#3 PostAuthor: paul doran » Sat Sep 15, 2018 10:08 am
I have clutch cover sprocket cover lower sanctions cam cover if You want it
front brake lever cable system master cylinder no cap
Roger Hill
#4 PostAuthor: Roger Hill » Wed Oct 10, 2018 11:25 am
Hi Garry
Do you still need Z1R Front brake parts ?
I have just found some parts while searching in boxes for some other stuff.
I have the master cylinder body (no piston) with the master cylinder end lever and pivot pin and the reservoir with cap with hose and clips.
They are in scabby condition but you can have them if they are of any use to you.
Let me know if you want them.
Users browsing this forum: Bing [Bot], Kwackman and 26 guests
