clocks
john richardson
clocks
#1 PostAuthor: john richardson » Sun Aug 05, 2018 12:50 pm
good afternoon, can any one out there help me please , im rebuilding a 1979 Z1R its going well so far, but im struggling to find certain parts IE the foam damper for around the clocks and the complete lock set. if any one knows where i can these item please let me know THANKS JOHN.
Re: clocks
#2 PostAuthor: chrisNI » Sun Aug 05, 2018 1:15 pm
ttiw
Re: clocks
#3 PostAuthor: Philippe » Sun Aug 05, 2018 2:26 pm
Hi John
as Chris mentioned before, show us some pictures please. We all love to see some pictures!
I restored a Z1R ('78 D1) myself in 2014-2015 and some parts seem to be made of unobtanium...I had to buy them allover Europe and North America...not to frighten you, only to warn you if you want it completely original.
As far as your foam around the clocks is concidered; do you mean the foam on top or at the bottom?
The ones on top can be bought as a replica, the foam at the bottom is difficult to find. You can always make one yourself using a strip of insulation foam. The original foam has a tendency to deteriorate when times goes by...
The lockset ( ignition, seat, helmet) could be bought until some time ago. Maybe they can help you at Z-power, just send a mail and ask.
Maybe someone ellse here can give you a lead.
Good luck with the restoration and please, please post some pictures!!!
wheelysteve
Re: clocks
#4 PostAuthor: wheelysteve » Sun Aug 05, 2018 5:39 pm
Contact member compoz1r on this forum. He makes them and they are top quality.
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
DavidZ1R
Re: clocks
#5 PostAuthor: DavidZ1R » Sun Aug 05, 2018 8:08 pm
Second that, compo has got them spot on.
john richardson
Re: clocks
#6 PostAuthor: john richardson » Mon Aug 06, 2018 12:19 pm
Philippe wrote:Hi John
HI Philippe thanks for take the time to reply . think compo z1r has the bottom foam inserts im looking for as for the lock set i can get them individually then will have to get a locksmith to alter the barrels so one key fit all. im also after a rear brake caliper . ps i have the bike stripped down and the tank is off to paint . i have one picture of the bike when i bought it about 6 weeks ago. will add it when i figure out how too !
Re: clocks
#7 PostAuthor: Philippe » Mon Aug 06, 2018 2:04 pm
Hi John
the rear brake caliper is the same as the one from a Z1000A1 or A2, allthough the piston can be different, not in diameter but with a "heat shield " inside.
As far as posting pictures is concerned: go to the bottom of the "reply" form, click on "attachments" (left corner) , click on "Add files" and load up a picture from your archive. Next, click on "edit" and it's done. I think you can add 8 or 9 pictures at the same time.
As far as the locks are concerned: You can find a locksmith to change the barrels , but I think you can buy a complete set with one key. I've seen it somewhere in the past but the price was rather high ( 250 Euro or so for the complete set). I change the barrels myself and you can be sure about one thing: It's a hell of a job to get the barrels out especially from the helmlock!
But, I'm not a locksmith!
Good luck
john richardson
Re: clocks
#8 PostAuthor: john richardson » Mon Aug 06, 2018 4:35 pm
Hi philippe as requested a picture of the Z1r When i bought it . Will upload more as i rebuild it as its all over my garage floor at the monent
Re: clocks
#9 PostAuthor: Philippe » Mon Aug 06, 2018 6:47 pm
Hi John
you did it!
Seems like a good bike to me! A rather complete bike with a big fuel tank, great. Thanks for the picture!
Take some pictures of the parts all over the garage, you'll be glad to have some memories of it for the future, believe me.
Good luck with the restoration!
john richardson
Steering lock
#10 PostAuthor: john richardson » Sun Aug 12, 2018 12:47 pm
Hi i need some help again , can any one tell me how to remove the steering lock from thr Z1R im rebuilding the only problem is the bike came with no keys
Last edited by john richardson on Sun Aug 12, 2018 3:43 pm, edited 1 time in total.
DavidZ1R
Re: clocks
#11 PostAuthor: DavidZ1R » Sun Aug 12, 2018 3:27 pm
Can you find the key number, it should be stamped on the other locks, keys are available.
john richardson
Steering lock
#12 PostAuthor: john richardson » Sun Aug 12, 2018 3:54 pm
Hi Dave z1r, got no other locks on the bike
Spoke to( compo) on this site and after speaking to him i have drilled it out, so im now locking for a lock set for a 1979 Z1R . If anyone out there has them please get in touch .ps dave thanks for taken the time to read my post john.
john richardson
The rebuild
#13 PostAuthor: john richardson » Sat Oct 13, 2018 1:10 pm
Just started the rebuild of my 1979 Z1R. I will upload more photos as it comes together.
Re: clocks
#14 PostAuthor: Garry.L » Sat Oct 13, 2018 2:15 pm
Looking good John. :D
Out of interest what engine paint you using?.
I've read/heard 1001 different opinions on what paint to use and it's longevity.
john richardson
Rebuild
#15 PostAuthor: john richardson » Sat Oct 13, 2018 3:38 pm
Hi Gary. I used SIMONIZ satin black, heat resistant spay paint you can get it from euro parts.its about £10
