I'm unable to use the electronic speedo pick up on the front wheel due to fork change has anyone used a pick up from say sproket ? Or what speedo options are you using . I would prefer to use std clocks but I'm open to other options.
Gpz1100b1 speedo options .
Re: Gpz1100b1 speedo options .
I have used Koso clocks, which the pickup can be on the wheel using a magnet. If you dont use your original clocks,I would be interested in buying them for my standard restoration.
Cheers Rob
Cheers Rob
Thanks but I'm afraid all the std parts must stay as I'm trying to build it with an option to return to std if required..
No probs, gpz 1100 a1 clocks work as well and i think they are cable driven
- 8 Valve Mark
what front front forks are you referring to? I'm assuming they come with a matching wheel.if it's a mechanical speedo drive from the front hub it should be a simple swap from the gpz1100 electronic set-up if you use a mechanically, eg cable driven speedo. if not it might be a headache.as mentioned earlier unitrack clocks work as they combine cable speedo drive with electronic rev counter and look nice lit-up of an evening..mark
Users browsing this forum: Bing [Bot] and 94 guests
