Rickman
Dunlop4
Rickman
#1 PostAuthor: Dunlop4 » Sun Nov 18, 2018 9:10 pm
This is my Rickman, which i have owned for a number of years. It needs partial reassembly, new tires, brake seals etc.
This is the finished engine freshly rebuilt, it has omega pistons gas flowed head and big valves.
I will post more pictures as work progresses.
Re: Rickman
#2 PostAuthor: Philippe » Mon Nov 19, 2018 5:18 am
Hi Dunlop4
looks great! Keep us informed by adding pictures, you know we all like that !
Good luck with the rebuild!
crossthread
Re: Rickman
#3 PostAuthor: crossthread » Mon Nov 19, 2018 9:14 am
Hoorah , another Rickman . What year ? Mine's registered 1980 . Keep the piccies coming, I love 'em.
Big Fluff
Re: Rickman
#4 PostAuthor: Big Fluff » Sun Nov 25, 2018 11:15 am
Very nice to see it as it should be too.
If you need any decals then give me a shout, I have a few complete kits left in stock in either gold or black (both short tank and long tank).
I also offer Rickman gauge face kits.
Dunlop4
Re: Rickman
#5 PostAuthor: Dunlop4 » Sun Nov 25, 2018 2:11 pm
OK i will bear this in mind as i work my way through this.
On the silver saxon what size tires and tubes did you use?
Big Fluff
Re: Rickman
#6 PostAuthor: Big Fluff » Mon Nov 26, 2018 2:58 pm
110 front, 120 rear, Pirelli Demons, bloody awesome tyres.
As for tubes, I think it was a 4.25 rear and a 4.10 for the front.
Dunlop4
Re: Rickman
#7 PostAuthor: Dunlop4 » Fri Dec 07, 2018 9:22 pm
I had new tyres fitted and bolted the wheels back in the frame.
Next fitting the engine.
The contrast of a black engine against a nickel frame, looks quite nice.
Here is a picture with the petrol tank on.
Re: Rickman
#8 PostAuthor: deka » Sat Dec 08, 2018 8:57 am
Loving this :luv
weaver
Re: Rickman
#9 PostAuthor: weaver » Sat Dec 08, 2018 9:16 am
looking good but that front mudguard needs replacing or reducing in size :wink:
Dunlop4
Re: Rickman
#10 PostAuthor: Dunlop4 » Sat Mar 02, 2019 7:29 pm
Update exhaust, generator connected.
Carbs fitted
Re: Rickman
#11 PostAuthor: deka » Sat Mar 02, 2019 9:22 pm
Love it I am a sucker for rickmans
Dunlop4
Re: Rickman
#12 PostAuthor: Dunlop4 » Sun Mar 03, 2019 4:09 pm
I installed the ignition system a Martek
I have an orange and red wire from the martek spare.
After connecting the battery there is no power.
Dunlop4
Re: Rickman
#13 PostAuthor: Dunlop4 » Sun Mar 03, 2019 4:40 pm
Spliced in the yellow and red wire from the martek, still no power.
Dunlop4
Re: Rickman
#14 PostAuthor: Dunlop4 » Sat Mar 16, 2019 5:53 pm
Success at last, have now got it started but only on two cylinders. The fuse needed connections needed cleaning.
The green wire from the martek is not powering up the coil for 2-3 cylinders, in effect running on 2 cylinders
Dunlop4
Re: Rickman
#15 PostAuthor: Dunlop4 » Sun Mar 17, 2019 3:52 pm
I fitted a Dyna s ignition
After swapping the wires around it started.
