Can any one tell me the thread size of the float bowel drain screws fitted to the Mikuni VM28SS carbs ?
i.e the carbs fitted to both Z1000 MKII & Z1R.
Nick
MKII Carb question
Re: MKII Carb question
Hi Nick
I don't know the size but they're the same as all the others (Z1A, Z1B, Z900A4, Z1000A1, Z1000A2, Z1R,...)Alltough some have drain holes and others don't.
You can buy them seperately with the O-ring at Z-Power.
Quick guess M4
Sorry didn't read the drain screw part.
"Set the GRINDER on it"
They are a fine thread m6, i have just looked.
Thanks guys that's very helpful.
I want to get some adapters made up so that I can set all the service fuel levels at the same time - unless someone knows where I can buy them?
Take a look at "classickawaparts" in Holland. Willem sells the adapters. I have one myself and it works great!
https://www.classickawaparts.nl/grote_h ... _meter.htm
Willem understands English, so go for it!
Thanks Philippe
You're welcome !
