Gpz1100b1 rear sets
Gpz1100b1 rear sets
Guys, what different types of aftermarket rear sets are out there for Gpz1100b1. I would like some sort of ability to take a passenger if possible.
Re: Gpz1100b1 rear sets
"Set the GRINDER on it"
I flogged a set of Tarozzis a couple of weeks ago with rear pegs to go with them. Not much help to you but if you look for the For Sale post you’ll see the setup. On a 1000R but would be the same.
chrisNI wrote:I flogged a set of Tarozzis a couple of weeks ago with rear pegs to go with them. Not much help to you but if you look for the For Sale post you’ll see the setup. On a 1000R but would be the same.
Chris.
Do you think it is possible to mount the rear sets through the original hanger mounting holes and therefore be able to fit a set of single tarozzi rear pegs or keep the original pegs in the original hangers?
Gus
Tomforde in Germany again, does some very nice ones but a little pricey.
https://www.ebay.co.uk/itm/Aluminium-Ma ... :rk:3:pf:0
Showing one left in stock at Disc V.
Need to specify folding or non folding footrests!!
https://www.discovolantemoto.co.uk/kawa ... 1141-p.asp
Gus
The Tarozzi rearsets I had used the hanger holes so I don’t think you can use both with that type. The ones in Al’s link are different and seem to use the hangers. The best bet with the non hanger type is a set of clamp on rear pegs like the ones I sold too, unfortunately I don’t know what they came off originally.
I like the Tomforde ones. That covers the riders pegs, what could I do for the rear pegs?
These are the rear pegs Chris had.
They could be an option if we knew what they were off.
If anybody recognises them that would be a great help as I could do with some also.
I'm a tight git and would prefer the buy this type off ebay option
Gus
Julian_Boolean
Raask rearsets have pillion peg mounts, try M and P for them.
The Raask ones seem ok but can’t see where the pillion pegs would be.
Julian_Boolean
scott wrote:The Raask ones seem ok but can’t see where the pillion pegs would be.
The holes right at the back are for pillion pegs, the big holes are for the exhaust mounts.
The riders footpegs are quite a long way back.
I'm a tight git and would prefer the buy this type off ebay option![]()
Gus
A lot of sportbike pegs can be easily adapted, either by welding a tab under the downtube or drilling and welding in a sleeve. Pictured are early R1 pegs.
