I have had a look in search and still unsure about location of ignition switch key number. I have found a faint number on the switch housing 025-0U77, I dont think this is a key number. Do i have to remove the roll pins to gain access to the ignition barrel and thd number?
Cheers Rob
Z1000j ignition switch key number
Re: Z1000j ignition switch key number
the no is normally stamped very small where the pin for the steering lock exits the switch the no will start with a letter Z you will need a magnifier glass to read the no
