Zed thou restoration restarted
RALPHARAMA
#76 PostAuthor: RALPHARAMA » Tue Mar 11, 2008 12:00 am
Have had some carb pain and grief but all is now sorted. She is pretty much finished save the exhaust:-
I just couldn't resist pressing the tit - she roared into life. Obviously I could only run her for a second or so with no exhausts, but at least in proved that she lives.
Ralph Ferrand
Skunkwurcx
#77 PostAuthor: Skunkwurcx » Tue Mar 11, 2008 3:18 pm
Beautiful job Ralph !! I wish I could be over there for April 20th. There are only a few Z's over here that I even know of, and the only one that I have ever seen with it's rubber on the road has been my mate's Z1-B.
#78 PostAuthor: Pigford » Tue Mar 11, 2008 6:01 pm
Ralph, that box section s/arm you out bid me & Jack for, won't look right on that Gleam Machine :wink:
By the way everyone RALPHS GARAGE AIN'T USUALLY THAT TIDY :shock:
RALPHARAMA
#79 PostAuthor: RALPHARAMA » Tue Mar 11, 2008 10:34 pm
To be fair it usually is - it's only whilst I've been playing with the bike it's got in a mess! The rest of the house is a shit hole mind :twisted:
You told me about the swinger! I can't believe it's your fault I had to pay so much for it! :wink:
Ralph Ferrand
ollie
#80 PostAuthor: ollie » Tue Mar 11, 2008 10:49 pm
Looking good Ralph,your 15 year old is going to miss you when the rays of spring come
ollie :wink:
Big John
#81 PostAuthor: Big John » Tue Mar 11, 2008 11:02 pm
Looking well good, bet you're pleased with it so far.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
RALPHARAMA
#82 PostAuthor: RALPHARAMA » Sun Mar 16, 2008 6:49 pm
Well she's pretty close to finished now. Just need tidy 'arris, speedo cable and mirrors.
I decided that I would fit the scabby 'arris I already have so that I could make up the new bracket. That wasn't easy - I had to fit the bloody thing to the bike and tack weld it with the TIG insitu. I don't like welding so close to new paintwork.
Here's the bracket anyway:
I took the old girl for a quick lap of honour around the village as a bit of a shakedown.
:beam :beam :xbou :beam
Here's how she looked when I got back:
There was a bit of an oil weep which I thought might be the sump, but I'm not so sure now. I re-torqued the sump bolts and that may have cured it. If not I'll drop the sump and this time I'll use some Wellseal instead of grease, my prefered choice. I might have only gone a short distance, but it felt real good :D
Ralph Ferrand
phil churchett
#83 PostAuthor: phil churchett » Sun Mar 16, 2008 6:57 pm
Lookin' good Ralph, roll on summer!
RALPHARAMA
#84 PostAuthor: RALPHARAMA » Sun Mar 16, 2008 7:52 pm
Here's how she was last May!
Ralph Ferrand
Geoff Meager
#85 PostAuthor: Geoff Meager » Sun Mar 16, 2008 8:30 pm
That is one beaut :D
Nice to see one that good ( better than a ShitFighter anyday )
Steve R
#86 PostAuthor: Steve R » Sun Mar 16, 2008 8:51 pm
That looks fantastic, not much beats riding a bike that you have built yourself, its a real credit to you, well done.
PJones
Z1000
#87 PostAuthor: PJones » Sun Mar 16, 2008 9:19 pm
Looking good Ralph,
Bet you can't wait for the summer to get some miles on it!!
WHO NEEDS DRUG'S
RALPHARAMA
#88 PostAuthor: RALPHARAMA » Mon Mar 24, 2008 8:02 pm
Charging isn't what it could be. Have ordered a new reg/rec from Z1 Enterprizes and another new speedo cable. Having put A2 forks on with the calipers at the back the standard A1 cable wouldn't fit. There's a bit of a oil weep which I think is coming from the ignition casing under the advance/retard unit. I only used grease on the gaskets as in my purist mind that is good. I'll re-seal using Wellseal as 30years down the road grease clearly isn't the answer. As it only weeps when the engine is running and hot, it's not 100% obvious, it could even be from the bolt that holds the two halves of the crankcase together in that area. Only time will tell. Have ordered a few gaskets form Z1Ent as well, to cover my generous arse :??
There's a very slight hicup at lower revs which I am guessing is down to the rather iffy pilot screws. I have sent a couple of e-mails to Z1 Enterprizes enquiring after them, but they don't seem to be communicating at the moment, prolly too busy to be dealing with limeys :(
The old gurl should be ready for the Ace, assuming the weather improves in the next month. Wild horses wouldn't get me sat on her for hours on end in these temperatures :lol:
Ralph Ferrand
RoyNorway
#89 PostAuthor: RoyNorway » Mon Mar 24, 2008 9:40 pm
Really nice bike :D
And in that colour combination...so beautiful :D
Nice work indeed on the bike. :clap
I use Threebond liquid gasket, very satisfied, they make the original Kawabond.
Ordered it from Z1 Enterprises. Really nice shop that is.
Z1000J 82 model, and Z1000R 83 model, And The Calfshit-GPZ1100-
Ed Z1-R
#90 PostAuthor: Ed Z1-R » Tue Mar 25, 2008 9:55 am
Looks nice,i like it :up
