Engine cases
- Regular Poster
Engine cases
Hi folks, does anyone have engine case's lying about I could have cheap as mine are very damaged on the bike I just bought. Cheers Mike
- Regular Poster
- 8 Valve Mark
Re: Engine cases
those will polish up ok. speak to mikey.
Re: Engine cases
Grim,
If you do manage to buy some cheaply, I'd suggest they would probably need more work to get them looking good than the ones you already have. With some time and patience, start by using a file to remove the deeper dings, followed by progressive grades of wet and dry paper, eventually finishing with 1200 grade, then using Solvol or similar...you'll be amazed how much they can be improved.
- Regular Poster
Re: Engine cases
Thanks folks, who's Mikey ?
- paul doran
Re: Engine cases
Mike Knowlson
search for Him under trusted traders
excellent bloke with a gift for making bits shiny
Re: Engine cases
look what he did with the brake plate (shameless plug) in the for sale section and the lower part of that is rippled if you look on your own.. again top fella and as the guys above say you wont get ones in as nice condition as you already have
Re: Engine cases
Hi Grim
the alloy cases on your bike can surely be polished up! As Steve says, use abrasive paper, start with coarse (grain 120) continue with middle (grain 320) and end up with fine (600 or more) . Afterwards you can polish them and they'll be like new.
Take a look at the cases of the Z1B I've restored ( Projects, Z1B restoration) The cases that were on that engine were terrible. With a lot of patience, the correct tools and a lot of elbow grease they became shiny. If I can do that, you can do it too! Go for it, give it a try, after all what do you have to loose?
Good luck
Good luck
Re: Engine cases
As said above.
The cases below were not as scratched but had lots of pitting in places, the same principle applies though, ie Progressive grades of Wet & Dry then get rubbing with the polish.....
Before...
During (after Wet & Dry)...
After a bit of a polish....
Before...
Re: Engine cases
Did this ti mine with deep scratches
Before
And after... still waiting for a nice buff
Before
- ZedHead
Re: Engine cases
deka wrote:Did this ti mine with deep scratches
....and a month later, after asking for cheap cases that may be better, even though cheap, than the perfectly serviceable items in the original post, only 10 posts ever made, not even a thank you for the pointers of help!!!
Mark.
Mark.
Re: Engine cases
Careful, he is the Grim Reaper after all!
Anywho, for the lazy there is always this... http://www.z-power.co.uk/points-cover-dohc-z1-z1000
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
- ZedHead
Re: Engine cases
Mark.
Mark.
Re: Engine cases
He’s obviously buggered off
another example of people jumping on the site hoping for cheap bits!
- Regular Poster
Re: Engine cases
Wrong ! Just thought I had seen all the replies, fuck me, you wouldn't have to step out of line on here. Didn't bank on Gonzo the enforcer being straight on my case after 18 days ( not a month) but thanks to the decent folk that did help. Cheers Mike.
