Ok, i have completely stripped and painted the rear brake master cylinder for my Z1000 A1. I have a repair kit in hand and am at the stage of re-assembly.
The old plunger is on the left and the new one on the right. How do I get the seal on without destroying it.
Obviously it goes on but its very tight and I don't want to tear or stretch it. Also I am at a loss as to what lubricant I could put on that won't affect its operation.
Nico
Rear Master Cylinder Rebuild
Re: Rear Master Cylinder Rebuild
get yourself some red rubber grease (oohh err mrs).
Its what recommended
chrisu wrote:get yourself some red rubber grease (oohh err mrs).
Correct answer.
wrap some electrical tape around the end of the piston to prevent damage to the seal
before fitting drop it in a cup of just boiled water and use the tips above as well
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
along with some lesser makes
Z1300 A1,
KE175b, KE175F
all of the above worked on mine
