Re Z1000a1 needles in an Z1000 A2
Is this a good swop , as the a2 ones are leaner
Re: Re Z1000a1 needles in an Z1000 A2
Hi Snowy
are you talking about the needle bearings of the swing arm?
They're the same , the only difference is that the A1 swing arm has only place for one on each side and the A2 swing arm has two on each side.
Carbs ?
Sorry Guys , il be more specific , Yes carb main jet needles , speaking to z power , Kawasaki no longer sell , and twith the rebuild kits , the main jet needles are not coded,
- warren3200gt
Have you tried allens performance. http://www.allensperformance.co.uk/shop/
waiting on e mail , got pilots there
Cybike list 2 different full carb rebuild kits , but dont seem to sell jet needles separate
I might have a set of new and unused Keyster needles kicking about if that helps.
Thank you so much ultim , but think I will try to replace with mikunis, was the A2 ,s different jet needles for leaner running ?
snowyz9 wrote:Thank you so much ultim8 , but think I will try to replace with mikunis, was the A2's different jet needles for leaner running ?
No worries.
Not sure about why, but I would suspect it was all push towards less emissions and thus leaner running...
Thanks Ultim
