z power center stand
gpjes
#1 PostAuthor: gpjes » Sun Mar 31, 2019 8:32 am
Anyone ever had a problem with the leg arm of the z power main stand bending on operation? I bought a brand new one a few years ago never used it, and sold it to my mate who spent a few hours fitting it to his A4 hoho, if you must have the four pipes :D expect the extra work, yes he's bent it so its lower than the LH foot of the mainstand so a bit wobbly :biggrin just wondered if anyone else has had a problem with this bit? I can probably move it back upwards with a bit of gentle pressure :twisted:
More Smiles Per Mile
chrisw1
Re: z power center stand
#2 PostAuthor: chrisw1 » Sun Mar 31, 2019 6:07 pm
mine fitted perfectly 1st time and has been great ....I also have 4 pipes
crossthread
#3 PostAuthor: crossthread » Mon Apr 01, 2019 8:53 am
Did I mis-read that? What's bent , the stand or the exhaust ? A stand that that you can bend back with " gentle pressure " sounds a bit dodgy !!!
#4 PostAuthor: Garry.L » Mon Apr 01, 2019 9:37 am
Don't know if it's the same with Zeds but Seem to recall this coming up a while ago with Pattern Triple stands. Seems the metal is much thinner and easier to bend.
A1John
#5 PostAuthor: A1John » Mon Apr 01, 2019 11:16 am
I got one last year no problems just a strong as the original.
flateddie
#6 PostAuthor: flateddie » Mon Apr 01, 2019 11:42 am
I have one on my z1000 a1 and its spot on
#7 PostAuthor: Ultim8pc » Mon Apr 01, 2019 9:21 pm
Having seen the stand in question, I'd say it's a repro - I have never seen an OEM stand bend and crease. I would suspect that if you bend it back it will go again.
Return to “The Bottom Shed”
