1976 Z900 Swinging Arm
Dero
#1 PostAuthor: Dero » Fri Apr 26, 2019 7:19 pm
I am looking for a standard Swinging Arm to fit my 1976 Z900, I’m told that the
Z1 Swinging Arm from a 1972 up to 1976 are all the same, they then changed to fit the rear disc brake.
I am also looking for a Main Stand if anyone has one they would like to sell.
8 Valve Mark
Re: 1976 Z900 Swinging Arm
#2 PostAuthor: 8 Valve Mark » Fri Apr 26, 2019 7:35 pm
hi dero, welcome to the z1oc, i have a swinging arm in the stash, (you're right about the years) it'll be a week or so before I can retrieve it cos its in my unit miles away. if you are in no rush let me know n I'll try to help. m
Dero
#3 PostAuthor: Dero » Fri Apr 26, 2019 8:40 pm
Hi Mark
Thank you for the welcome.
I can’t ride my bike without it, I have a 4 into 4 exhaust that won’t fit the bike with my Metchex
Swinging arm.
If you have one I will wait.
How much do you want for it?
Regards Derrick
tim.25
#4 PostAuthor: tim.25 » Sat Apr 27, 2019 7:12 am
Hi Derrick
I may be interested in your metchex arm if you are thinking of selling it.
Regards
Tim
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
Dero
#5 PostAuthor: Dero » Sat Apr 27, 2019 8:50 am
Hi Tim
I will have no use for the Metchex Swinging arm once I get a standard one.
As soon as I get a standard one I’ll let you know.
Where in the country are you? Close enough to see it fitted before I remove it?
Also
Just for your information the 4 into 4 exhaust catches on the Swinging arm so if you have a standard system you may want to look into changing to a 4 into 1, I have just taken off a Kerker 4into 1 if you need one.
Derrick
tim.25
#6 PostAuthor: tim.25 » Sat Apr 27, 2019 11:43 am
P.m sent.
Dero
#7 PostAuthor: Dero » Sat Apr 27, 2019 2:19 pm
Nothing received yet
