Anyone know where I can get some? I need 4 for a set of Z1000 A1 Carbs. I have a set which are lacking them.
Does anyone know if they will run without?
Guy
16012-022 Cap Limiters
Re: 16012-022 Cap Limiters
As you have found, not available new anymore.
You don't need these for the bike to run. They are just little extenders which allow you to easily adjust the airscrews while the carbs are on the bike. But you can still adjust them with short screw driver.
I have been after some for a while, no joy.
Not reproduced to the best of my knowledge.
ZedHead wrote:Not reproduced to the best of my knowledge.
+1 to that..
Thanks all for the info, its as I thought but wanted to check. Appreciate the feedback.
Guy
Guy, i recently bought a couple of sets of those hens teeth. They were not cheap. I'll check how many i have left. Send me a pm and we'll get some to you.
- warren3200gt
Is there any truth in the alleged "go to method" of screwing the fuel needle closed and then only using the airscrew mixture screw to adjust pilots as per normal airscrew only carbs
Will do
scott wrote:Guy, i recently bought a couple of sets of those hens teeth. They were not cheap. I'll check how many i have left. Send me a pm and we'll get some to you.
Guy
