Z1000 mk2 neutral
Tony(hank)harper
Z1000 mk2 neutral
#1 PostAuthor: Tony(hank)harper » Thu Jun 20, 2019 4:36 pm
Folks
Would a 1982 z1000 have the three ball bearings to stop overstepping neutral from first when stationary?
Re: Z1000 mk2 neutral
#2 PostAuthor: Pigford » Thu Jun 20, 2019 4:59 pm
Yes
Gus
#3 PostAuthor: Gus » Thu Jun 20, 2019 5:01 pm
Ye indeedy do
Gus
"Set the GRINDER on it"
Tony(hank)harper
#4 PostAuthor: Tony(hank)harper » Thu Jun 20, 2019 6:52 pm
Thanks.
Looks like somebody's left them out on the motor I've got.
Goes straight into second from first.
Big job ahead
johny brando
#5 PostAuthor: johny brando » Sat Jun 29, 2019 1:15 am
Tony(hank)harper wrote:Thanks.
Big job ahead
If in doubt & the c /case are apart and in front of you ! Best get in there slide of the gears off & have a Visual , as they may be there....& just jammed in the retracted position maybe gummed up or at some stage maybe got rusty so they don't roll or slide as well as they are meant to ? , this would allow a First to Second gear change without the shafts revolving as they should do.
Cheers Johny B
Users browsing this forum: No registered users and 105 guests
