z900 a4
John A4
z900 a4
#1 PostAuthor: John A4 » Mon Jul 15, 2019 6:57 pm
Hello All, Ive had a bit of a battle with the head on my Z900 and have now given up.!!
Does anyone have a spare head that's in good order ? or know of one?
Re: z900 a4
#2 PostAuthor: Ultim8pc » Mon Jul 15, 2019 8:57 pm
What's the issue with your head that makes you want to replace it?
John A4
Re: z900 a4
#3 PostAuthor: John A4 » Wed Jul 17, 2019 6:43 pm
Hi Mate, I had a loose valve guide and a piece of head broken away and with bad advice from a so called expert, had the head welded which distorted the valve track. engineer trued it up with a new oversize guide but oil still getting into the head and smoking on start up.
Head back off and you can see the oil tracking in through the exhaust valve, so not sure if the weld is porous or not?
Any advice would be gratefully received.
John 07976 554950
Re: z900 a4
#4 PostAuthor: Ultim8pc » Thu Jul 18, 2019 9:12 am
John
Sorry to hear that - sounds like a nightmare.
I think you are saying that oil is getting between the valve stem and head interface or the weld?
Does sound like your best bet in another head, but then you'd still need to get it checked and reworked.
You can use a z900 or 1000 head as they are identical barring the exhaust stud diameters.
Re: z900 a4
#5 PostAuthor: ZedHead » Thu Jul 18, 2019 10:44 am
Try Buzzard he might be able to sort a good one.
