Evening Gents.
I want to fit a set of rear sets to a project but they have a 2 hole mounting system for a master cylinder which are 45 mm centre fitting. All the ones I have are all 50mm. Could somebody point me in the direction of a 45mm fitting rear master cylinder.
Cheers Amigos
Gus
Rear brake master cyl question
"Set the GRINDER on it"
Re: Rear brake master cyl question
i have a tl1000s one in my garage just measured that & its 45mm between centres & 6mm threaded mounting
Excellent
Thanks for the info, much appreciated
Gus
Gus
Users browsing this forum: bigdjag and 48 guests
