Z1000 A1 Rear hub.
thezfactor
Z1000 A1 Rear hub.
#1 PostAuthor: thezfactor » Tue Aug 06, 2019 6:17 pm
Good Afternoon All,
I have just purchased a Z1000 rear hub (minus the sprocket carrier and cush rubbers) and I’ve inherited a small problem ! Has anyone had any experience in removing the steel spoke carrying saucer that is fitted on one side of this hub please ? The hub is a very useable but it’s a scabby thing and requires a very good clean up, the saucer is rusty, slightly pitted and has the chrome peeling off in some areas. So I really need to split these items if at all possible. So far I have tried pressing with a small amount of heat and all to no avail, I can’t imagine that it’s threaded unless of course you know different. Many thanks.
Keefleaf
Re: Z1000 A1 Rear hub.
#2 PostAuthor: Keefleaf » Tue Aug 06, 2019 7:27 pm
Eddie Scarlett knows someone who provides this service.
Prob’ best not to try yourself ?
#3 PostAuthor: ADRIAN H » Tue Aug 06, 2019 8:01 pm
It’s a press fitting almost impossible to remove.
flateddie
#4 PostAuthor: flateddie » Wed Aug 07, 2019 8:53 pm
There is a bike custom business which built the blue z1000 with the nickel plated frame which is on ebay for 15.5k item number 123848223131 they built a tool for removing the chrome spoke disc.
