Anyone ever run the stock airbox with smoothbores?? I am not happy with the Emgo or K&N pod filters,plus the side covers do not fit properly. I think the carbs would need low jets maybe 15 pilots and 117.5 mains. Appriecate your advice
Gregz
Stock airbox with 29 smoothbores yes /no
Z1
1965 Corvette
1965 Corvette
Hi Greg,
I have just bought a full standard airbox for my Z1000A2 which is fitted with 29mm smoothbores. At the moment it has individual air filters which I am not too happy about. I will be taking the bike to the local dyno guy for a full session to sort out the jetting and can let you know the outcome. It will be a couple of weeks though as the airbox is coming from the USA.
padders
padders
- RALPHARAMA
That's about 4-5?C
In the UK we talk about cold weather in Celcius and Hot weather in Farenheight.
Prolly about that here in Zomerzet - Took my beloved Zed up the Chinese in town tonight - only 'bout six or seven miles so not enough for the cold to penetrate the leathers but the blast through the vents in my lid was a tad bracing! Awesome feeling
Ralph Ferrand
- Jeff Saunders
The airbox will give far better air quality to the bike at all speeds. The problem on the dyno is it doesn't show you the effects of turbulence around the back of the engine at different speeds.
With velocity stacks on a bike, you can impact the way the bike runs just by moving your legs in and out to deflect air differently.
I agree, You only have to look at bikes without an airbox and you can see fuel stains behind the carburretors where the turbulant air has drawn mixture backwards out of the venturis, with an airbox all the air is going forward and not affect by the air your bike is pushing through. I mentioned the dyno testing to address any doubts regarding air intake being restricted by using an airbox over velocity stacks or individual filters, although we have seen loss of power when cheaper individaul foam filter have been fitted. The larger airducts for the flatslide carbs works just like a velocity stack but into a big volume of still air. If you look at nearly all of the pro stock bikes now (where they can not rely on turbo or nitrous for additional power gains) you wil see that the one piece body work is sealed to create a huge airbox, this provides a large quantity of still air. Regards, Steve
