Later Z1000/GPZ1100 starter gears etc.
Zomerset Zed
#1 PostAuthor: Zomerset Zed » Mon Sep 02, 2019 1:02 pm
Thought i'd start a new thread to see if anyone has got and is willing to part with some parts i need to complete fitting a starter to my P and M 1170?
I have all i need apart from:
Tapered hub (either an existing later dished type rotor which i can remove the hub from and then fit the starter clutch to, or an Electrex one). I currently have an enquiry in with Electrex for a new one, but i'm not holding my breath!
The following parts from the diagram below:
STARTER ASSY.jpg (100.17 KiB) Viewed 2713 times
21 and 24, both washers/spacers
23 main gear to fit later crank with 25mm shaft/30mm bearing OD, 45mm ID sprag clutch:
STARTER GEAR LARGE.jpg (120.91 KiB) Viewed 2713 times
26 pinion gear:
STARTER GEAR SMALL.jpg (69.63 KiB) Viewed 2713 times
27 pin for pinion gear:
I have all the other parts already.
I don't mind obtaining a part from here or there.
Thanks in advance.
Gus
Re: Later Z1000/GPZ1100 starter gears etc.
#2 PostAuthor: Gus » Mon Sep 02, 2019 2:12 pm
https://www.kawasakioriginalparts.com/p ... =13002-007
https://www.kawasakioriginalparts.com/p ... 92026-1033
https://www.kawasakioriginalparts.com/p ... 92026-1031
https://www.kawasakioriginalparts.com/p ... 16085-1012
Plenty of pinion gears on ebay they fit everything from a Z1 onwards according to parzilla.
Also the STARTER GEAR / MAIN GEAR fits all these
Kawasaki Motorcycle 1997 Police 1000 - KZ1000-P16 Starter Motor
Kawasaki Motorcycle 2000 Police 1000 - KZ1000-P19 Starter Motor
Kawasaki Motorcycle 1992 Police 1000 - KZ1000-P11 Starter Motor
Kawasaki Motorcycle 1999 Police 1000 - KZ1000-P18 Starter Motor
Kawasaki Motorcycle 2001 Police 1000 - KZ1000-P20 Starter Motor
Kawasaki Motorcycle 1996 Police 1000 - KZ1000-P15 Starter Motor
Kawasaki Motorcycle 1995 Police 1000 - KZ1000-P14 Starter Motor
Kawasaki Motorcycle 1993 Police 1000 - KZ1000-P12 Starter Motor
Kawasaki Motorcycle 1991 Police 1000 - KZ1000-P10 Starter Motor
Kawasaki Motorcycle 1994 Police 1000 - KZ1000-P13 Starter Motor
Kawasaki Motorcycle 1998 Police 1000 - KZ1000-P17 Starter Motor
Kawasaki Motorcycle 1988 Police 1000 - KZ1000-P7 STARTER MOTOR (KZ1000-P6/P7/P8)
Kawasaki Motorcycle 1987 Police 1000 - KZ1000-P6 STARTER MOTOR (KZ1000-P6/P7/P8)
Kawasaki Motorcycle 1989 Police 1000 - KZ1000-P8 STARTER MOTOR (KZ1000-P6/P7/P8)
Kawasaki Motorcycle 1990 Police 1000 - KZ1000-P9 STARTER MOTOR (KZ1000-P9/P10)
Kawasaki Motorcycle 1985 Police 1000 - KZ1000-P4 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 Police 1000 - KZ1000-P2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1982 Eddie Lawson Replica - KZ1000-R1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1984 Police 1000 - KZ1000-P3 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1986 Police 1000 - KZ1000-P5 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1980 Shaft - KZ1000-E2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 Spectre - KZ1100-D2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1982 Spectre - KZ1100-D1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1982 Police 1000 - KZ1000-P1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 Eddie Lawson Replica - KZ1000-R2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1979 Shaft - KZ1000-E1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1980 Classic - KZ1000-G1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 GPz - ZX1100-A1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1983 LTD Shaft - KZ1100-L1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1985 LTD Shaft - ZN1100-B2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1984 LTD Shaft - ZN1100-B1 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1984 GPz - ZX1100-A2 Starter Motor / Starter Clutch
Kawasaki Motorcycle 1978 KZ1000 - KZ1000-A2A STARTER MOTOR/STARTER CLUTCH ('79-'80 A3
Kawasaki Motorcycle 1979 KZ1000 - KZ1000-A3 STARTER MOTOR/STARTER CLUTCH ('79-'80 A3
Kawasaki Motorcycle 1979 KZ1000 - KZ1000-A3A STARTER MOTOR/STARTER CLUTCH ('79-'80 A3
Kawasaki Motorcycle 1977 KZ1000 - KZ1000-A1 STARTER MOTOR/STARTER CLUTCH ('79-'80 A3
Kawasaki Motorcycle 1978 KZ1000 - KZ1000-A2 STARTER MOTOR/STARTER CLUTCH ('79-'80 A3
Kawasaki Motorcycle 1980 KZ1000 - KZ1000-A4 STARTER MOTOR/STARTER CLUTCH ('79-'80 A3
Kawasaki Motorcycle 1980 LTD - KZ1000-B4 STARTER MOTOR/STARTER CLUTCH ('79-'80 B3
Kawasaki Motorcycle 1977 KZ1000 LTD - KZ1000-B1 STARTER MOTOR/STARTER CLUTCH ('79-'80 B3
Kawasaki Motorcycle 1979 KZ1000 LTD - KZ1000-B3 STARTER MOTOR/STARTER CLUTCH ('79-'80 B3
Kawasaki Motorcycle 1978 KZ1000 LTD - KZ1000-B2 STARTER MOTOR/STARTER CLUTCH ('79-'80 B3
Kawasaki Motorcycle 1981 Police 1000 - KZ1000-C4 STARTER MOTOR/STARTER CLUTCH ('79-'81 C2
Kawasaki Motorcycle 1980 Police 1000 - KZ1000-C3 STARTER MOTOR/STARTER CLUTCH ('79-'81 C2
Kawasaki Motorcycle 1978 Police 1000 - KZ1000-C1 STARTER MOTOR/STARTER CLUTCH ('79-'81 C2
Kawasaki Motorcycle 1979 Police 1000 - KZ1000-C2 STARTER MOTOR/STARTER CLUTCH ('79-'81 C2
Kawasaki Motorcycle 1978 Police 1000 - KZ1000-C1A STARTER MOTOR/STARTER CLUTCH ('79-'81 C2
Kawasaki Motorcycle 1980 Z1R - KZ1000-D3 STARTER MOTOR/STARTER CLUTCH ('80 D3)
Kawasaki Motorcycle 1978 Z1R - KZ1000-D1 STARTER MOTOR/STARTER CLUTCH ('80 D3)
Kawasaki Motorcycle 1983 KZ1000-J3 STARTER MOTOR/STARTER CLUTCH (KZ1000-J1)
Kawasaki Motorcycle 1981 KZ1000-J1 STARTER MOTOR/STARTER CLUTCH (KZ1000-J1)
Kawasaki Motorcycle 1982 KZ1000-J2 STARTER MOTOR/STARTER CLUTCH (KZ1000-J1)
Kawasaki Motorcycle 1981 KZ1000-J1 STARTER MOTOR/STARTER CLUTCH (KZ1000-J2/
Kawasaki Motorcycle 1983 KZ1000-J3 STARTER MOTOR/STARTER CLUTCH (KZ1000-J2/
Kawasaki Motorcycle 1982 KZ1000-J2 STARTER MOTOR/STARTER CLUTCH (KZ1000-J2/
Kawasaki Motorcycle 1981 LTD - KZ1000-K1 STARTER MOTOR/STARTER CLUTCH (KZ1000-K1)
Kawasaki Motorcycle 1982 LTD - KZ1000-K2 STARTER MOTOR/STARTER CLUTCH (KZ1000-K1)
Kawasaki Motorcycle 1982 LTD - KZ1000-K2 STARTER MOTOR/STARTER CLUTCH (KZ1000-K2)
Kawasaki Motorcycle 1981 LTD - KZ1000-K1 STARTER MOTOR/STARTER CLUTCH (KZ1000-K2)
Kawasaki Motorcycle 1982 CSR - KZ1000-M2 STARTER MOTOR/STARTER CLUTCH (KZ1000-M1)
Kawasaki Motorcycle 1981 CSR - KZ1000-M1 STARTER MOTOR/STARTER CLUTCH (KZ1000-M1)
Kawasaki Motorcycle 1982 CSR - KZ1000-M2 STARTER MOTOR/STARTER CLUTCH (KZ1000-M2)
Kawasaki Motorcycle 1981 CSR - KZ1000-M1 STARTER MOTOR/STARTER CLUTCH (KZ1000-M2)
Kawasaki Motorcycle 1981 Shaft - KZ1100-A1 STARTER MOTOR/STARTER CLUTCH (KZ1100-A1)
Kawasaki Motorcycle 1983 Shaft - KZ1100-A3 STARTER MOTOR/STARTER CLUTCH (KZ1100-A1)
Kawasaki Motorcycle 1982 Shaft - KZ1100-A2 STARTER MOTOR/STARTER CLUTCH (KZ1100-A1)
Kawasaki Motorcycle 1981 Shaft - KZ1100-A1 STARTER MOTOR/STARTER CLUTCH (KZ1100-A2/
Kawasaki Motorcycle 1983 Shaft - KZ1100-A3 STARTER MOTOR/STARTER CLUTCH (KZ1100-A2/
Kawasaki Motorcycle 1982 Shaft - KZ1100-A2 STARTER MOTOR/STARTER CLUTCH (KZ1100-A2/
Kawasaki Motorcycle 1981 GPz - KZ1100-B1 STARTER MOTOR/STARTER CLUTCH (KZ1100-B1)
Kawasaki Motorcycle 1982 GPz - KZ1100-B2 STARTER MOTOR/STARTER CLUTCH (KZ1100-B1)
Kawasaki Motorcycle 1981 GPz - KZ1100-B1 STARTER MOTOR/STARTER CLUTCH (KZ1100-B2)
Kawasaki Motorcycle 1982 GPz - KZ1100-B2 STARTER MOTOR/STARTER CLUTCH (KZ1100-B2)
"Set the GRINDER on it"
Zomerset Zed
#3 PostAuthor: Zomerset Zed » Mon Sep 02, 2019 3:12 pm
I have the starter clutch :rock
What i do need most is the 2 x gears and the hub/rotor. Yes of course i could go out and buy new gears for £200 but that's a lot more than i could buy them for if someones has got them unwanted........
Gus
#4 PostAuthor: Gus » Mon Sep 02, 2019 3:16 pm
My apologies just trying to help.
The list above is for the STARTER GEAR / MAIN GEAR it is just part of the title in partzilla.
Part 16085
Part number 16085-1012
