How do I get the carbs off as the airbox on an A4 is tight up against the frame ?
sprint wrote:The existing rubbers are perfectly soft and pliable.
My question was how do you physically remove and replace them in situ, as they are secured by a clamping plate that is screwed from the front of the airbox which are inaccessible with the carbs fitted?
They can't be removed from the inside of the airbox.
