Clock top removal
Gavin
Clock top removal
#1 PostAuthor: Gavin » Sun Oct 06, 2019 4:10 pm
Hi guys
I need to remove the meters from the clock uppers ( thinking of getting them chromed, how do I get them out without destroying the retaining band
Z1000 MK2
Z1300 DFI
Charlie
Re: Clock top removal
#2 PostAuthor: Charlie » Mon Oct 07, 2019 5:43 pm
You can't. The band has to be cut off and it needs a pro tool to fit a new one without it showing. You can buy chrome top clock covers that fit over the top though.
Blackseven
#3 PostAuthor: Blackseven » Mon Oct 07, 2019 6:59 pm
The crimping rings can be careflly unpicked on the back to seperate the clock cases. New rings are available from a French seller via Ebay and with a bit of ingenuity and patience can be fitted without any visible marks and with no special tools.
Pictured below are my clocks that I fitted new faces and crimp rings to using nothing more than some plastic vent tubing from B&Q, masking tape and a big cable tie. The front face of the crimp rings are completely unmarked, the back faces do pick up some marks but if you fit the rebuilt clocks with Emgo clock bottoms, they are slightly wider than standard where the fit to the crimp ring and conveniently hide this.
Mark Tiller
#4 PostAuthor: Mark Tiller » Mon Oct 07, 2019 7:04 pm
if you get a sharp tool like a scriber or bradawl you can gradually open the silver ring from underneath .....then it can be resealed again gradually by crimping back with a flat tool
07962421462
#5 PostAuthor: ADRIAN H » Mon Oct 07, 2019 7:12 pm
Link to an article from USA, shamelessly pinched from a USA forum. :oops:
https://wgcarbs.com/index.php/using-joo ... auge-clean
#6 PostAuthor: ADRIAN H » Mon Oct 07, 2019 7:15 pm
previous thread on Z1OC.
viewtopic.php?f=4&t=42149
wilsonsjw11
#7 PostAuthor: wilsonsjw11 » Tue Oct 08, 2019 5:35 am
Al Marshal on this site can offer this service too.
Regards
Steve
Big Fluff
#8 PostAuthor: Big Fluff » Tue Oct 08, 2019 2:59 pm
ADRIAN H wrote:Link to an article from USA, shamelessly pinched from a USA forum. :oops:
:oops: Truly horrendous way of "crimping" the retaining ring with a big fat pair of pliers! :lol:
000zeds
#9 PostAuthor: 000zeds » Tue Oct 08, 2019 4:33 pm
wilsonsjw11 wrote:Al Marshal on this site can offer this service too.
Regards
Steve
http://z-clocks.co.uk/
Zeds-R-Us
