Tank screws
Tank screws
#1 PostAuthor: deka » Wed Oct 09, 2019 8:30 pm
Anyone know the size of the tank badge screws for a z900
Re: Tank screws
#2 PostAuthor: warren3200gt » Wed Oct 09, 2019 9:27 pm
Parts manual lists them as
SCREW, coutersunk head 3mm thread x6mm long.
PUM 488 June 2023
8 Valve Mark
Re: Tank screws
#3 PostAuthor: 8 Valve Mark » Wed Oct 09, 2019 9:59 pm
zpower sell them..
Re: Tank screws
#4 PostAuthor: deka » Thu Oct 10, 2019 9:13 am
they do Mark but they are a £1 for 4 + vat which is fine and then £3.50 for postage, which tbh is a but much and i dont need anything else at the moment
MikeP
Re: Tank screws
#5 PostAuthor: MikeP » Thu Oct 10, 2019 9:26 am
The screw is 221C0306 which is only £0.14 each from Kawasaki UK.
I use Cradley Heath and postage is free
MikeP
Re: Tank screws
#6 PostAuthor: MikeP » Thu Oct 10, 2019 9:31 am
Re: Tank screws
#7 PostAuthor: deka » Thu Oct 10, 2019 11:41 am
Thanks Mike ordered and free postage result plus standard equipment :-)
MikeP
Re: Tank screws
#8 PostAuthor: MikeP » Thu Oct 10, 2019 1:43 pm
:up
Re: Tank screws
#9 PostAuthor: ZedHead » Thu Oct 10, 2019 2:13 pm
How many do you need?
hartyb
Re: Tank screws
#10 PostAuthor: hartyb » Thu Oct 10, 2019 5:03 pm
are they the Same for all Z1000 Modles as i will need about 7 plus sets for all sorts of models
at 14p if they are all the same i will buy 20 units in one hit and really push the boat out :lol:
anyone know what the thred pitch mite be so i can find a tap as I have some that need to be sorted before paint
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
MikeP
Re: Tank screws
#11 PostAuthor: MikeP » Thu Oct 10, 2019 6:57 pm
I imagine they'd be the same M3 thread, if it's an M3 x 6 csk - but accept I may be wrong. Could check on CMSNL.
Just checked the screws I bought for the Gpz1100B1 and the Z1000R2 last week, which are the same for those two models and the same part number as the Z900 A4 - 221C0306 which is superceded by 221AB0306
hartyb
Re: Tank screws
#12 PostAuthor: hartyb » Fri Oct 11, 2019 1:10 pm
fab info thank you
Z1300 A1,
KE175b, KE175F
Reecy
Re: Tank screws
#13 PostAuthor: Reecy » Fri Oct 11, 2019 9:45 pm
And when you use them.........
Make sure that you check that they aren't too long, it is possible to screw through the badge, through the mounting bar and perforate the tank-that's not a good outcome, be careful
trikerdrew
Re: Tank screws
#14 PostAuthor: trikerdrew » Sat Oct 12, 2019 8:59 am
local fastener place they would be peanuts.....
and yes , I am a tight git! :mrgreen:
hartyb
Re: Tank screws
#15 PostAuthor: hartyb » Tue Oct 15, 2019 11:30 am
trikerdrew wrote:local fastener place they would be peanuts.....
then they would be Phillips and not Japanise Industry Standaed
JIS cruciform driver sizes[1]
Driver
size Machine Screw
Size
#000
#00
#0
#1 M2, M2.2, M 2.5
#2 M3, M3.5, M4, M4.5, M5
#3 M6, M8
The JIS B 1012 is commonly found in Japanese equipment. It looks like a Phillips screw, but is designed not to cam out and will therefore be damaged by a Phillips screwdriver if it is too tight. Heads are usually identifiable by a single dot or an "X" to one side of the cross slot.[29]
Specific "JIS" standardized cruciform-blade screwdrivers are available for this type of screw.
Z1300 A1,
KE175b, KE175F
