Black Fuel Tap (73)
marmck
Black Fuel Tap (73)
#1 PostAuthor: marmck » Tue Oct 08, 2019 2:34 pm
As title, looking for a original 73 fuel tap ,black THKs :D
73z1
Re: Black Fuel Tap (73)
#2 PostAuthor: 73z1 » Sun Oct 13, 2019 2:41 pm
https://www.ebay.com/itm/Kawasaki-Z1-90 ... ondition=4
Warning: 73 z1 used a rubber sleeve, no longer available.
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sun Oct 13, 2019 5:19 pm
The tap levers shown are the early 73 type without the later added O ring and leak badly.The replacement seal is the part also needed on a tap rebuild but are hard to come by.The later levers c/w 'O' ring are available on ebay.
Regards
Steve
marmck
#4 PostAuthor: marmck » Thu Oct 17, 2019 5:03 pm
wilsonsjw11 wrote:The tap levers shown are the early 73 type without the later added O ring and leak badly.The replacement seal is the part also needed on a tap rebuild but are hard to come by.The later levers c/w 'O' ring are available on ebay.
Regards
Steve
Thanks 4 that ,so do the later levers with 0 ring fit early tap bodies .
wilsonsjw11
#5 PostAuthor: wilsonsjw11 » Fri Oct 18, 2019 2:58 pm
Yes they do.
73z1
#6 PostAuthor: 73z1 » Sat Oct 19, 2019 11:48 pm
Yes they do
marmck
#7 PostAuthor: marmck » Tue Oct 29, 2019 4:55 pm
Image[/quote]
Any chance of buying a pan head screw , that holds the lever in place , you kind gentleman :D
marmck
#8 PostAuthor: marmck » Tue Nov 05, 2019 3:56 pm
All sorted bar the filters ,now this turns up typical - https://www.ebay.co.uk/itm/KAWASAKI-197 ... SwwKpdwXL5
marmck
#9 PostAuthor: marmck » Sun Nov 17, 2019 2:29 pm
Put the original tap on , but lets a bit of fuel out on the off position , so back on with the repro one.Well i Tried !
wilsonsjw11
#10 PostAuthor: wilsonsjw11 » Sun Nov 17, 2019 5:40 pm
You need the replacement seal for the rebuild to be successful.
Regards
Steve.
marmck
#11 PostAuthor: marmck » Sun Nov 17, 2019 6:02 pm
wilsonsjw11 wrote:You need the replacement seal for the rebuild to be successful.
Regards
Steve.
The only seal I have not replaced is the rubber sleeve that slides on to the lever, is this the one that needs replacing , thanks for the input by the way
wilsonsjw11
#12 PostAuthor: wilsonsjw11 » Sun Nov 17, 2019 6:28 pm
The seal you have described is the item required,if you get one apply red rubber grease when rebuilding the tap and on yearly basis to keep it soft and pliable.
Regards
Steve
bedlow1
#13 PostAuthor: bedlow1 » Sun Nov 17, 2019 6:46 pm
does anyone have an image of one fitted to the lever?
1972 Z1 Euro Spec
1975 Z1B UK Bike
marmck
#14 PostAuthor: marmck » Mon Nov 18, 2019 11:18 am
Is this what you wanted
wilsonsjw11
#15 PostAuthor: wilsonsjw11 » Mon Nov 18, 2019 2:49 pm
That is the seal, the tap lever is new?
Regards
Steve
Users browsing this forum: zed9 and 34 guests
