My Z1000A1 Rider has quit charging, I have bought a replacement all in One regulator / rectifier unit, But it comes with no fitting instructions.
I assume that the beige wires on the unit should go where the 3 Yellow wires went - Is there a specific order for these or can they go anywhere?
White obviously goes to positive
Black to Earth
Now this "Grey" wire at the bottom I assume is to the regulator, but, obviously the regulator has Four wires, Pink, Blue, Yellow and Orangey/Brown.
Any help would be appreciated chaps
Thanks.
Advice please gentlemen . .
Re: Advice please gentlemen . .
I would say that the grey wire is gona be the voltage sense wire which is the brown in the multi plug, This is a switched live in the loom and " monitors" the battery voltage, in the past I have attached em direct to,the battery + with no ill effects, this just means in effect you will be getting true battery voltage on the wire and not 40 year volt drops....your call
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Thanks for that Keith! . . I'll keep you posted.
Lifes too short . . .
