Z10000 MK2: front brake disc
Sgt.Pinback
#1 PostAuthor: Sgt.Pinback » Wed Nov 27, 2019 10:25 am
Does anybody have a MK2 workshop manual and may have a look:
when are the front brake discs worn (min. mm)?
Cheers, Uli
Re: Z10000 MK2: front brake disc
#2 PostAuthor: Ultim8pc » Wed Nov 27, 2019 10:38 am
I believe it is 4.5mm but I'll check for you.
Sgt.Pinback
#3 PostAuthor: Sgt.Pinback » Wed Nov 27, 2019 10:46 am
Thanks, would be great.
Maybe you find the mm when new as well.
Cheers, Uli
#4 PostAuthor: Ultim8pc » Wed Nov 27, 2019 10:48 am
Sgt.Pinback wrote:Thanks, would be great.
5mm when new I believe
Sgt.Pinback
#5 PostAuthor: Sgt.Pinback » Thu Nov 28, 2019 2:11 pm
Did you find the data?
Cheers, Uli
#6 PostAuthor: Ultim8pc » Thu Nov 28, 2019 2:12 pm
Sgt.Pinback wrote:Did you find the data?
Sorry, haven't looked but I am sure it's 5mm new and 4.5 minium
CAT3
#7 PostAuthor: CAT3 » Fri Dec 06, 2019 4:09 pm
Minimum thickness is the same as the A4 discs, standard is 5.0mm & service limit is 4.5mm.
The service limit is cast into the disc carriers.
This is assuming it's a European model, it's possible the Yank versions used the thicker disc like the Yank A4's did.
Users browsing this forum: celger7 and 34 guests
