top idle sprocket
flateddie
top idle sprocket
#1 PostAuthor: flateddie » Sat Nov 30, 2019 9:38 pm
Anyone know what the difference between the z900 and z1000 top idle sprocket assembly? they are different part numbers but the APE ones do both bikes
johny brando
Re: top idle sprocket
#2 PostAuthor: johny brando » Sat Nov 30, 2019 9:55 pm
flateddie wrote:Anyone know what the difference between the z900 and z1000 top idle sprocket assembly? they are different part numbers but the APE ones do both bikes
They are a different design & not interchangeable with a Std 900 Cam cover ....if you wish to fit one you will need to change the Cam Cover to Z1000 as well....this due to a wider surface area where the wider Idler sits below. In my opinion the Z1000 idler wheel is a better design than the 900 one, as it can be disassembled easier than the 900 one that is designed as a one piece none serviceable item !
#3 PostAuthor: Pigford » Mon Dec 02, 2019 7:15 am
Have a word with Rob (Zed1015) - he makes/sells an improved/modified version!
