6mm crankcase bolts
buzzard
6mm crankcase bolts
#1 PostAuthor: buzzard » Thu Dec 05, 2019 7:04 pm
Evening peeps, as the title says looking for any 6mm thread 10mm head crankcase or sump bolts, any length any condition. Buzzard
Every man should have a shed (for bikes obviously..)
Re: 6mm crankcase bolts
#2 PostAuthor: warren3200gt » Thu Dec 05, 2019 8:05 pm
Should have plenty of 650 bolts for sump, crankcase and cam cover. I swopped em out for stainless socket head on my custom build. I'll check it out tomorrow. Anything in particular your after?
buzzard
#3 PostAuthor: buzzard » Fri Dec 06, 2019 12:35 pm
Afternoon Warren, I'm restoring a Z1A 900 to original condition, unfortunately the engine was previously assembled using Allen screws, so what I'm after is any length 6mm thread crankcase/sump bolts, the type that are 10mm head with the built in washer, from 25mm length up to the very long ones 116mm, any condition any length. Thanks. Buzzard@thebuzzworkz
#4 PostAuthor: warren3200gt » Fri Dec 06, 2019 1:57 pm
Hi Buzzard, found a few, see pic.Dims refer to underside of head to end of thread. Any of these any good to you? Damn Australian bolts!
buzzard
#5 PostAuthor: buzzard » Fri Dec 06, 2019 2:49 pm
Warren, there spot on, how much do you want for all of them? I already have a few but none of the smaller ones. Thanks. Buzzard@thebuzzworkz
#6 PostAuthor: warren3200gt » Fri Dec 06, 2019 2:55 pm
Ping me your adress and I'll get them out to you mate.
buzzard
#7 PostAuthor: buzzard » Tue Dec 10, 2019 10:03 am
Bolts arrived Warren, massive thanks. Buzzard@thebuzzworkz
needaz1100r
#8 PostAuthor: needaz1100r » Tue Dec 10, 2019 10:07 am
buzzard wrote:Afternoon Warren, I'm restoring a Z1A 900 to original condition, unfortunately the engine was previously assembled using Allen screws, so what I'm after is any length 6mm thread crankcase/sump bolts, the type that are 10mm head with the built in washer, from 25mm length up to the very long ones 116mm, any condition any length. Thanks. Buzzard@thebuzzworkz
http://www.z-power.co.uk/bolt-set-crankcases-6mm
Mark.
