Dimensions
needaz1100r
Dimensions
#1 PostAuthor: needaz1100r » Tue Dec 10, 2019 10:10 am
Please could somebody accurately measure the Z1000A2, behind the fork caliper slider bolts?
NLA and I have a set of calipers missing them so my only option is to make some unless anyone has a set to sell.
Mark.
Re: Dimensions
#2 PostAuthor: ADRIAN H » Tue Dec 10, 2019 11:31 am
Do you mean the slider bolts that fix the calliper mounting bracket to the calliper.
Or the actual calliper mount bolts on to the forks.
flateddie
Re: Dimensions
#3 PostAuthor: flateddie » Tue Dec 10, 2019 11:46 am
the bolts for mounting the calliper or the sliders are available along with the o rings and rubber boots try z power or Cybike
needaz1100r
Re: Dimensions
#4 PostAuthor: needaz1100r » Tue Dec 10, 2019 3:38 pm
Please guys give me a bit of credit, I know I look stupid but, the slider bolts that go through the caliper and the mounting bracket, I can work out the fork to caliper bolts.
They are not in stock and NLA at Z-Power as of 9.18 this morning.
Mark.
Re: Dimensions
#5 PostAuthor: ADRIAN H » Tue Dec 10, 2019 9:34 pm
needaz1100r
Re: Dimensions
#6 PostAuthor: needaz1100r » Tue Dec 10, 2019 10:51 pm
Thank you, I couldn't find any on Ebay. I'll message and see if they have any more in the morning.
Thanks again.
Mark.
Gus
Re: Dimensions
#7 PostAuthor: Gus » Wed Dec 11, 2019 9:14 am
"Set the GRINDER on it"
Gus
Re: Dimensions
#8 PostAuthor: Gus » Wed Dec 11, 2019 9:20 am
Borrowed from another post by KWACKERZ1
KWACKERZ1 wrote:Hi guys, Thought this price list from PHIL DENTON ENGINEERING may be a useful guide for people after stainless stuff.
I have no connection with them but have had them make me custom stuff and they have been really good.
http://www.phildentonengineering.com
Hope its useful
KAWASAKI Z900
SWING ARM SPINDLE NUT 92019-012 each 7.82
SWING ARM SPINDLE (also Later Z1B) 33032-036 each 51.49
CARB FLOAT BOWL DRAIN PLUG (NB can be brass for early models) 16049-005 each 11.89
REAR CHAIN ADJUSTER BOLT/NUT (M10) 92001-143 pair 18.68
REAR BRAKE ROD 43011-017 each 25.51
REAR BRAKE TRUNNION 92043-065 each 4.07
REAR BRAKE ADJUSTER 92015-056 each 8.05
ENGINE MOUNTING SPACER (long - 52mm) 92027-159 each 16.84
ENGINE MOUNTING SPACER (short - 31mm) 92027-160 each 9.36
REAR WHEEL SPACER 42032-037 each 14.18
FORK LEG TOP BOLT 44062-003 pair 38.99
STEERING STEM TOP BOLT & WASHER 92007-031/92022-230 each 22.09
STEERING STEM TOP BOLT WAVE WASHER 46100-003 each 0.00
STEERING HEAD BEARING ADJUSTER NUT 92090-007 each 21.77
STEERING HEAD DUST COVER 46098-010 each 25.51
FRONT WHEEL SPINDLE 41068-049 each 39.83
FRONT WHEEL SPACER 41069-032 each 8.80
FRONT WHEEL SLEEVE NUT (2 off req) 41069-033 pair 29.40
FOOTREST CUP WASHERS (4 off req) 92102-010 set 11.04
FOOTREST HANGER MOUNT ACORN NUT (set of 4) 92019-013 set 24.90
FRONT BRAKE CALIPER MOUNTING BOLT (set of 4) 92007-032 set 35.01
FRONT BRAKE CALIPER SLIDE BOLT AND NUT (set of 4) 43045-006 set 42.41
FRONT BRAKE CALIPER PISTON 43048-006 each 21.40
BRAKE CALIPER BLEED NIPPLE 43085-001 each 8.76
CHOKE PIVOT SCREW (Carb Body) 16046-005 each 5.52
CYLINDER HEAD NUT (set of 12) 92015-076 set 93.48
EXHAUST MOUNTING BOLT 92003-131 pair 35.10
REAR BRAKE TORQUE ARM BOLT - TO SWING ARM 92003-103 each 10.67
REAR BRAKE TORQUE ARM BOLT - TO BRAKE 92003-101 each 11.28
REAR SHOCKER MOUNTING BOTTOM BOLT 113N1035 each 7.58
REAR WHEEL SPINDLE 42031-034 each 65.44
REAR WHEEL NUT 42045-018 each 11.52
REAR WHEEL SPACER - BRAKE SIDE 42032-037 each 14.18
REAR WHEEL SPACER - SPROCKET SIDE 42037-023 each 7.59
REAR WHEEL WASHER - 4.5 THICK 92022-248 each 2.57
REAR WHEEL WASHER - 6.0 THICK 92022-249 each 2.57
FRONT BRAKE DISC MOUNTING BOLT (M10 X 32 ) - set of 8 92001-158 set 59.84
FRONT BRAKE BLEED NIPPLE 43085-001 each 8.76
FRONT FORK BOTTOM YOKE PINCH BOLT (M12 X 36) 92003-064 pair 17.46
FOOTREST PIVOT PIN 92043-080 pair 10.21
FOOTREST WASHER 92022-250 pair 2.99
PILLION FOOTREST PIVOT PIN 92043-079 pair 10.96
EXHAUST STUD - M6 (set of 8) 92004-049 set 34.44
EXHAUST STUD - M8 (set of 8) 92004-065 set 40.77
KAWASAKI Z1000
CYLINDER HEAD NUT (set 12) 92015-076 set 93.48
REAR BRAKE CALIPER PISTON 43048-008 pair 38.17
FRONT BRAKE CALIPER PISTON 43048-009 (A1) each 21.77
REAR BRAKE PEDAL TO M/CYL PUSH ROD BOLT 92003-198 each 8.61
F/R BRAKE CALIPER SLIDE BOLT (set 4) 43045-006 set 42.41
gUS
needaz1100r
Re: Dimensions
#9 PostAuthor: needaz1100r » Wed Dec 11, 2019 11:02 am
Gus wrote:Borrowed from another post by KWACKERZ1
Hope its useful
gUS
Thanks for this, very useful indeed.
Mark.
Re: Dimensions
#10 PostAuthor: ADRIAN H » Wed Dec 11, 2019 7:39 pm
Nice one.
Users browsing this forum: zed9 and 33 guests
