Tyres and tubes.
ianali
Tyres and tubes.
#1 PostAuthor: ianali » Fri Feb 21, 2020 12:09 pm
Looking to fit a new front tyre to my bike.T regd z1000. The current tyre is marked tubeless. The alloy wheel is Kawasaki 19” but isn’t as far as I could see marked as a tubeless wheel. Can I assume I can fit a new tubeless tyre, or might I find a tube lurking inside when I strip it off?
Re: Tyres and tubes.
#2 PostAuthor: Pigford » Fri Feb 21, 2020 1:06 pm
STD rim’s need a tube - the air tends to leak out of the spoke nipple holes :wink:
You can get kits to seal (special rim tape) but the fitment of tubeless on these rims is not truly compatible!
Andy M
#3 PostAuthor: Andy M » Fri Feb 21, 2020 2:27 pm
You should tell if it has a tube by the valve . It will have at that age
#4 PostAuthor: Philippe » Fri Feb 21, 2020 3:39 pm
Hi Ian
if the wheel is not marked "tubeless" you will find an inner tube inside. To my knowledge the '79 Z1000ST was the first Kawasaki bike with tubeless tires, the others needed an inner tube. Perhaps there were others, I don't know.
It's not a good idea to fit tubeless tires on a tube type wheel, the rim is different and the air leaks out.
Buy a set of good tires (Bridgestone BT 45) and use inner tubes.
Good luck with it.
Andrew_s
#5 PostAuthor: Andrew_s » Fri Feb 21, 2020 10:11 pm
Pigford wrote:STD rim’s need a tube.............
Will this do Mark...... :?:
Current Bikes:
2023 R1250 GSA
#6 PostAuthor: Pigford » Sun Feb 23, 2020 11:16 am
Yes
Obviously I didn’t read the first post fully :lol:
