Rear grab rail
QITMAN
Rear grab rail
#1 PostAuthor: QITMAN » Wed Mar 18, 2020 12:02 pm
Afternoon all
Has anybody installed Ohlins rear shocks and gone to fit the grab rail only to find it doesn’t fit anymore as the top of the shocks prevent two threaded lugs from lining up with the two frame holes!!!
Gutted.
Any fixes ????
Thanks Mike
Z900, Tuono RSV 1000, XL600R, DT100, KDX125, CL350
flateddie
Re: Rear grab rail
#2 PostAuthor: flateddie » Wed Mar 18, 2020 12:07 pm
sure I have seen them turned around so the reservoir is facing the front
scott
Junior Section leader
Re: Rear grab rail
#3 PostAuthor: scott » Wed Mar 18, 2020 1:22 pm
I fitted ohlins shocks to my z1000a2 and found that the lugs of the grag rail interefered with the shocks. The shock would be pushed slightly making it turn inwards. I removed the grab rail and machind/ground away the bit that fouled and then rewelded the hole. Then sent it for chroming. The modification is hardly noticable. I wondered when people would start to admit that fitting ohlins would have slight issues. If you need any pictures of the modifications then please ask.
QITMAN
Re: Rear grab rail
#4 PostAuthor: QITMAN » Wed Mar 18, 2020 9:22 pm
Scott
That would be great,
Mikemills@gmail.com
Mike
QITMAN
Re: Rear grab rail
#5 PostAuthor: QITMAN » Wed Mar 18, 2020 9:23 pm
Bloody heck!!!!
mikemills174@gmail.com
Re: Rear grab rail
#6 PostAuthor: chrisNI » Thu Mar 19, 2020 11:44 pm
scott wrote:If you need any pictures of the modifications then please ask.
Scott why not post them here for future reference...? :D :D
scott
Re: Rear grab rail
#7 PostAuthor: scott » Thu Mar 19, 2020 11:46 pm
Ok, will do tomorrow
QITMAN
Re: Rear grab rail
#8 PostAuthor: QITMAN » Sat Apr 04, 2020 6:41 am
Thanks for the advice lads, but I managed to get the rail to fit after being very gentle with a a grinder with different wheels.
No damage to the chrome, so as you cannot see the rework unless you look really really close, I’m going to seal the rail with metal paste.
Users browsing this forum: Dave6772 and 34 guests
