Brackets in front of battery case Z1000A1
compo z1r
Re: Brackets in front of battery case Z1000A1
#16 PostAuthor: compo z1r » Fri Apr 03, 2020 9:09 pm
No 20 bolts to frame with batt box and 15 bolts to batt box to support air box dont forget u will need all the collars and dampers with the brackets
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
TiBolts
#17 PostAuthor: TiBolts » Fri Apr 03, 2020 9:39 pm
Yes cheers thanks. I do seem to have most of the collars and dampers, plus some that I've had kicking about for about 30 odd years. They are a bit manky though but I see that I can get new ones.
