Z1100R ELR
RUSS243
Z1100R ELR
#1 PostAuthor: RUSS243 » Mon Apr 06, 2020 9:55 am
Hi to all out there
Been on here for a while but never had time to post till on furlough! Hope you all are well in these strange times.
I am looking for some unobtainium parts for 1100R Lawson Replica:
Front mudguard
Standard carbs and airbox
Footrest hangers
Fork brace
Clocks
Plastic cover that goes over the ignition key
Standard swingarm
Hopefully someone might have some of the parts though I know all are pretty rare!
Fingers crossed
Russ
Julian_Boolean
Re: Z1100R ELR
#2 PostAuthor: Julian_Boolean » Mon Apr 06, 2020 10:56 am
Is the airbox the same as a Z1000J one, if so I've got one I don't want
RUSS243
Re: Z1100R ELR
#3 PostAuthor: RUSS243 » Mon Apr 06, 2020 11:29 am
Hi Julian
Thanks for getting in touch. I think it is! Will double check and let you know.
Russ
Robw
Re: Z1100R ELR
#4 PostAuthor: Robw » Mon Apr 06, 2020 12:52 pm
Julian, are you sure you have it?
I have a selection of foot rest mounts and a swinging arm(no chain adjuster blocks). If they are the same as a j.
Rob
Julian_Boolean
Re: Z1100R ELR
#5 PostAuthor: Julian_Boolean » Tue Apr 07, 2020 12:49 pm
Robw wrote:Julian, are you sure you have it?
Rob
If it's not at mine it's at yours, I thought you threw it at me the other day :D poxy thing, it takes up a load of room, and still haven't found those handle bar switches, but I suspect I've got a box of switches somewhere, because there's some more I can't find.
Robw
Re: Z1100R ELR
#6 PostAuthor: Robw » Tue Apr 07, 2020 2:35 pm
You refused to take it back, stating you had no room at Chez Boolean.
:D All your parts are in that safe place :idea
Hugs Rob
Julian_Boolean
Re: Z1100R ELR
#7 PostAuthor: Julian_Boolean » Tue Apr 07, 2020 3:36 pm
I've made some room now by reassembling my Z, I just need some switchgear for it now, which I thought I had but can't find......
Robw
Re: Z1100R ELR
#8 PostAuthor: Robw » Tue Apr 07, 2020 5:42 pm
They will be in the same place as the j one you have for me. I have some basic switchgear if you want them? I know where mine are as well.
rpeters
Bristol's "H" Hoarder
Re: Z1100R ELR
#9 PostAuthor: rpeters » Wed Apr 08, 2020 6:02 am
I think I have a swing arm
paid up member
scott
Junior Section leader
Re: Z1100R ELR
#10 PostAuthor: scott » Wed Apr 08, 2020 6:47 am
I have footpeg hangers and footpegs if needed. Telefix fork brace any good to you?
Re: Z1100R ELR
#11 PostAuthor: Al » Wed Apr 08, 2020 10:00 am
Stand to be corrected;
Airbox is the same and has the model range printed on the front to include J and 1100R1 etc. though the side flashes are black chrome on the R1.
Footrest hangers are similar but different. The R1 type have two holes at the rear for mountings. I think J and GPz1100 will fit but not do the same job in one respect.
Swingarm is again similar but longer on the R1 and the rear; 'cast fork parts' are more substantial than the J version. I believe the R1 may also have bracing welded at the front between the cross tube and the outside of the trailing legs.
Front mudguard is unique to the 1100R1. Best you can hope for is to alter a standard J / Gpz1100 one by cutting off the side plates and welding on plain ones.
Fork brace from a J / GPz may or not fit. The bottom legs are unique to the 1100R1 and different in some respects though i cant say if this particular dimension is the same as the others. I have Scotts' Telefix here if you want dimensions etc.
RUSS243
Re: Z1100R ELR
#12 PostAuthor: RUSS243 » Fri Apr 10, 2020 10:14 am
Hi Guys
Great info! The dimension of the forks where the brace would fit looks to be 59.5mm? Think the the only option for a mudguard is as you say Al.
Russ
Re: Z1100R ELR
#13 PostAuthor: Al » Fri Apr 10, 2020 12:12 pm
Scott's fork brace is 59mm at the point you measured your forks so should clamp up just nicely.
The fixed distance centre to centre of the fork legs is 185 to 186mm although there is some movement / adjustment with the two 'through' fixing bolts.
RUSS243
Re: Z1100R ELR
#14 PostAuthor: RUSS243 » Sat Apr 11, 2020 3:58 pm
Hi Al
Sound spot on pal! Did you say ho w much you wanted for it?
Russ
Re: Z1100R ELR
#15 PostAuthor: Al » Sat Apr 11, 2020 5:03 pm
scott wrote:I have footpeg hangers and footpegs if needed. Telefix fork brace any good to you?
Hello Russ, that sounds encouraging.
I have the fork brace here because it was attached to a set of forks i bought from Scott a few weeks back.
It still belongs to him and had it not been for recent events he would have had it back by now.
Could i ask that you discuss; price, post, timing etc with him please.
All the best
Post Author: scott » Wed Apr 08, 2020 6:47 am
Users browsing this forum: Google [Bot], moizeau and 8 guests
