Z1R timing and carb set up required
New to this but I have a near fully restored Z1R that I bought a while back and need someone with the expertise and finesse to set timing and carbs up, its had Boyer Bransden ignition and re wire and also on foam filters with big bore kit, ideally someone not too far from South Yorkshire
Re: Z1R timing and carb set up required
Hi Scott welcome aboard.
Did you buy it rebuilt?
Cheers and yeah I did might get round to looking myself but just wondered if anyone could assist as knowledge is king
Welcome Scott pictures would be good?
Yeah I’ll try and sort some
Is it running at all or just running a bit rough?
Starts but then struggles to idle and abit of backfire
If its been standing a while, drain the float bowls , as a start point and maybe new plugs.
Todays fuel is so crap it gums up the pilot circuits in the carbs very easily.
If the fuels been in there longer than a few months, drain it out and put some fresh stuff in to be sure.
Yeah I always put super unleaded in my bikes anyway and yeah it has fresh fuel in, not checked plugs yet tho but will try and get round to it
Did u do the carbs ? If on pods is the corrector jets fitted have u had them balanced ? Timing is easy ? It’s just a awkward time of now not many will want to ride about yet ?
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Scott8210 wrote:Yeah I always put super unleaded in my bikes anyway and yeah it has fresh fuel in, not checked plugs yet tho but will try and get round to it
Plugs would be my first "port of call" as they are prone to fouling with the ethanol fuels nowadays, a new decent set is well worth it.
