How do I use the valve shim tool?
CAT3
Re: How do I use the valve shim tool?
#16 PostAuthor: CAT3 » Sun Apr 26, 2020 9:36 pm
There should be a cast boss on the cylinder head in line with each valve. The cut-out in the tool, (where the cap head screw is) fits over this boss.
As someone has said, if you can post a picture of the tool in position on your head it will almost certainly help.
#17 PostAuthor: Al » Sun Apr 26, 2020 9:39 pm
Dont know what happened there but as i pressed submit the content disappeared anyway this was it.
Looking at the pic of the tool you posted, i seem to remember the bottom of the curved part being thicker and having a recess in it. Perhaps its the angle the pic is taken at but that looks truncated!
CAT3
#18 PostAuthor: CAT3 » Mon Apr 27, 2020 9:14 am
This picture shows the locating boss for the shim tool for No.1 cylinder, inlet valve.
There are similar bosses for each valve on the outside edges of the head.
download/file.php?mode=view&id=16292
CAT3
#19 PostAuthor: CAT3 » Mon Apr 27, 2020 9:30 am
This is my shim tool, a genuine Kawasaki item. The arrow points to where the boss on the cylinder head should be positioned in order to change a shim. Hopefully this may help.
download/file.php?mode=view&id=16293
It is also important to ensure the tip of the tool is correctly located against the shim bucket.
download/file.php?mode=view&id=16294
#20 PostAuthor: chrisu » Mon Apr 27, 2020 9:37 am
see the sticky at the top.
If you need any more info feel free to message/call me
1340fxd
#21 PostAuthor: 1340fxd » Mon Apr 27, 2020 10:09 am
Many thanks for the pictures CAT3 and everyone who has tried to help. This all confirms that I am placing the tool correctly. However it is clear that the tool (in the middle) is not the same as the original Kawasaki tool. Z-Power are sending me another one which differs from their latest batch. Wait and see time...
Shim tools.JPG (45.44 KiB) Viewed 5480 times
Dear Santa, please can I have...
#22 PostAuthor: kev edwards » Mon Apr 27, 2020 10:28 am
I have the Z power tool and whilst it has a smaller cut out in the tip, it works fine, forgive me me for asking are you following the instructions correctly,here is the link on here.
viewtopic.php?f=4&t=7216
1340fxd
#23 PostAuthor: 1340fxd » Mon Apr 27, 2020 12:01 pm
Hi Kev - yes I'm using it correctly but mine has no cut-out at all. Z-Power say their recent supply looks different from what they have had and are sending me old stock.
Big Fluff
#24 PostAuthor: Big Fluff » Mon Apr 27, 2020 12:41 pm
Pigford wrote:KZShimTool-1.jpg
I wonder how many people had a go at making one like I did the design for many years ago.
I still have mine and it's still working wonders, gives a bit of satisfaction knowing you've made it yourself and it actually works. :lol:
#25 PostAuthor: kev edwards » Mon Apr 27, 2020 1:25 pm
1340fxd wrote:Hi Kev - yes I'm using it correctly but mine has no cut-out at all. Z-Power say their recent supply looks different from what they have had and are sending me old stock.
Can you not file the tip flat, it will do the job then, there should be plenty to lift the shim out when done.
#26 PostAuthor: kev edwards » Mon Apr 27, 2020 1:29 pm
I am going to make one on this lock down even though I have both types already I also have a specially adapted screwdriver somewhere which I used on my first Zed, it worked just as well.
#27 PostAuthor: kev edwards » Mon Apr 27, 2020 8:59 pm
Been meaning to make one for years, so with time on my hands and a bit of rubbish I knocked this one out this afternoon, just need to make it look nice now.
1340fxd
#28 PostAuthor: 1340fxd » Wed Apr 29, 2020 5:04 pm
Replacement tool arrived today from Z-Power - works a treat! They were really quick to sort it too. Good on you - making your own. :D
#29 PostAuthor: Pigford » Thu Apr 30, 2020 8:27 am
kev edwards wrote:Been meaning to make one for years, so with time on my hands and a bit of rubbish I knocked this one out this afternoon, just need to make it look nice now.
Looks good, but next time use titanium & drill it out with extra holes for added cool & performance :!:
#30 PostAuthor: kev edwards » Thu Apr 30, 2020 9:58 am
And with all the weight saving will be faster :D
