Wheel Paint - What to Use?
bulldogbobby
#1 PostAuthor: bulldogbobby » Fri Mar 13, 2020 9:53 am
Need to replace my tyres but noticed that a small area of the rear wheel paint has started to scratch off :cry: The front wheel is spot on and so is the rest of the rear - can only assume that that section wasn't cleaned down properly before the top coat went onto the primer. :cry: Needs to be 100% right before I put the wheels back on the bike so gonna strip both wheels down and repaint them with rattle cans (again!). I used Simoniz last time - had a look through old posts but can't find a real recommendation for wheel paint? I need something close to the satin black original and it HAS to be hard-wearing. This has been recommended on other forums?
https://www.frost.co.uk/frost-extreme-h ... ack-500ml/
What about applying a satin clear coat afterwards? Any other advice? (apart from powder coating!...........)
nicomkii
Re: Wheel Paint - What to Use?
#2 PostAuthor: nicomkii » Mon Mar 23, 2020 5:12 am
I used Wurths Satin Black on both my MkII and A1. MkII has done 25000km and paint has performed excellently.
Nico
bulldogbobby
#3 PostAuthor: bulldogbobby » Thu Apr 30, 2020 7:49 am
nicomkii wrote:I used Wurths Satin Black on both my MkII and A1. MkII has done 25000km and paint has performed excellently.
Only just seen your reply but thanks for the info mate - after a bit of research, I've gone for U-Pol PCEP/AL Powercan Etch Primer and U-Pol Powercan Top Coat Satin Black. Fingers crossed! :D
KWACKERZ1
#4 PostAuthor: KWACKERZ1 » Fri May 01, 2020 8:06 am
To pick up on your earlier note,
The Frost or eastwoods extreme chassis black is great stuff, I use it on all black frame stuff its very hardwearing.
Just wish they did a silver version as well. But definitional recommended.
zince
#5 PostAuthor: zince » Fri May 01, 2020 10:33 pm
Hi
I have a new BT45 back Tyre in Norwich 50.00 quid if you need one ..
Vince
HD/GS/Z1/Z900RS/ Norton
bulldogbobby
#6 PostAuthor: bulldogbobby » Sun May 03, 2020 11:29 am
zince wrote:Hi
Vince
Hi Vince - bloody marvellous! Would definitely have had it but have already bought and fitted a set of BT45's.
Cheers anyway mate
#7 PostAuthor: ADRIAN H » Sun May 03, 2020 2:25 pm
bulldogbobby wrote:Need to replace my tyres but noticed that a small area of the rear wheel paint has started to scratch off :cry:
I use Frost restorations- Eastwood Satin Black wheel paint - but paint after new tyres fitted. Mask tyres off with wedges of card all round.
bulldogbobby
#8 PostAuthor: bulldogbobby » Mon May 04, 2020 7:22 am
Thanks mate :up
bulldogbobby
#9 PostAuthor: bulldogbobby » Thu May 07, 2020 7:41 am
Polished and Painted.
Pleased with the results - let's see how they hold up :D
#10 PostAuthor: ADRIAN H » Thu May 07, 2020 1:16 pm
bulldogbobby wrote:Polished and Painted.
Looking Good. :D :D
bulldogbobby
#11 PostAuthor: bulldogbobby » Fri May 08, 2020 10:53 am
Looking Good. :D :D
:D :up
Thanks mate
Users browsing this forum: Bing [Bot] and 261 guests
