Lithium ion batteries
Zedorset
#1 PostAuthor: Zedorset » Fri May 15, 2020 8:10 pm
Hi all
I am thinking of putting a lithium ion battery on my Z1B, I am pissed off at buying new batteries every year as I am unable to get electrickery to run trickle charger in my garage, has anyone done this if so is there anything I need to do?
Jon
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Re: Lithium ion batteries
#2 PostAuthor: chrisu » Sat May 16, 2020 6:05 am
Minimum have a modern solid state reg/rec on the bike.
#3 PostAuthor: Pigford » Sat May 16, 2020 7:05 am
They need to be charged at a higher rate than lead-acid/gel (so what Chris said).
I used on on my old Harris Z1000 and it was fine for 2 yrs use (the sold it :roll: )
Zedorset
#4 PostAuthor: Zedorset » Sat May 16, 2020 7:37 am
Thanks, I do have a modern reg/rec so looks to be a good way forward.
1975 Kawasaki Z1B
#5 PostAuthor: chrisu » Sat May 16, 2020 8:01 am
and a liFe specific charger to be safe.
rickm
#6 PostAuthor: rickm » Sat May 16, 2020 9:07 am
I've now got LiFe batteries on all 3 of my bikes, and don't regret it at all.
I know that there are a few cautionary things that need considering (charge rate, having a good reg/rectifier, etc). I may just be lucky, but I've not had a problem, even with 40 yr old electrics on the bikes.
Without stating the obvious, you just need to make sure you get a size that will fit your battery box. When I looked, a lot of them seem to be 5mm wider than the standard battery. You can usually make these fit, but just something to be aware of.
H2B GPZ900R
