Hello All, trying to get my gpz1100b1 back on the road, started cleaning it up not "concourse" but clean and usable..striped most of it down now after getting things power coated putting it back, done 85k miles from new, when i bought it in 81...injection all still works...but ad to replace original "tv screen" as it all failed, so looking for a replaement.
The only issue i have is although i have the original service manual, and it does show hat i am after, i dont know when it goes. OK there is a blue with red stripe cable that come out of the crankcase from behind the starter motor, it comes from the loom under the starter motor, comes out from behind the starter motor just near the rear camchain tensioner, but because its sheared about a cm up from the crankase i cant find the other end as i have stripped all injectors out and moved the loom about. i did take loads of "before" photos but cant see anything in them. so if anyone can let me know .....
GPZ11000B1
Re: GPZ11000B1
Hi tjaski
welcome to the club!
Put some pictures of your bike on here, before and during the restoration.
Tell us something more about yourself and your bike in the "New here"section.
Come on, don't be shy!
Greetings from Belgium.
Re: GPZ11000B1
Thanks for that but i already have a blue with red stripe going there, the One i am holding Is from the loom to the oil pressure switch, the other photo just shows another Blue with red stripe coming out of the crankcase, albeit i have had to solder and shrink wrap a new extension on It...
Re: GPZ11000B1
Hi tjaski
is your bike equipped with a side stand switch ? Where does the blue wire goes to ? Into a multi pin connector?
A lot of questions I know but we don't get much information coming from you...
Give us some more pictures to make things a bit clearer. Perhaps we can give you better answers then.
Re: GPZ11000B1
The RED/BLUE wire from the oil pressure switch goes from the switch itself, through that little rubber grommet, under the starter motor and into a thin 'sub loom' which has in it; three yellow wires and one from the neutral switch. That wire is pictured in place in youre second photo.
The additional RED/BLUE wire you are holding could be the only other RED/BLUE wire that appears in a UK B1wiring diagram and if so it is part of the fuel injection sub loom.
P.S. I am the last person to trust with electrics
Re: GPZ11000B1
Ok stripped the loom where the existing Blue/ Red wire goes from the loom to the pressure switch, and as i remember 39 years ago It went in for its 8k service. Now the only Blue/Red cable IS from the loom to the pressure switch via that crankcase opening with the grommet. When It went in they found a fault with that cable, cit the cable in the loom and just made a extension from the damaged part in the loom straight to the pressure switch bypassing the cable in the crankcase.
Re: GPZ11000B1
Hi tjaski
I have no idea what they did so many years ago...The B1 oil pressure switch is at the bottom of the oil pan but there's a wire running above the upper crankcase to what? Did they put a new oil pressure switch at the departure of the oil line running towards the oil cooler?
I have no clue...try to take some more pictures maybe it becomes clear that way.
Re: GPZ11000B1
Ok, Will try to explain what i have found, on mine the oil pressure switch Is located on the top, at the rear of the crankcase. The cable Blue/Red stripe, goes from this then down into the crankcase, then CES back up the loom at the top of the plenum chamber. The last photo i poster shows the Blue/Red cable spliced with shrink wrap connected to the Blue/Red cable that comes down the loom, you can see in the loom where the stub of the Blue/Red cable still exists, this Is the original bit that goes down the loom, and comes up behind the starter motor, out through the Rubber grommet then into the pressure switch. Not sure of that all makes sense...but all working now.
Re: GPZ11000B1
Hi tjaski
Now I see it! OK ! So they swapped the oil departure of your B1 with an oil departure of an older Z with an oil cooler. That way they could measure the oil pressure on top of the crankcase while leaving the original switch in the sump. They had to connect the wire of the "new"oil pressure switch with the wire coming from underneath.
As long as it works it's fine. Thanks for the additional picture! One pictures says more than a thousand words!
If you want to swap it to original you need a working B1 oil pressure switch in the sump and an original oil departure on top of the crankcase and change the non original parts with those and connect the original wires again.
Re: GPZ11000B1
Thanks for your help, as i am working forwards, my next problema are rounded sump plug, and rounded filter bolt , used grips, refiled the simo plug, but still gets rounded, used a 1 metre breaker,....Will be applying some heat tomorrow. Plus a sheared exhaust manifold stud, heat to that too.
Users browsing this forum: No registered users and 73 guests
