Genuine Z1 exhaust clamp for No3 cylinder.
wilsonsjw11
As the title says, genuine Z1 exhaust clamp for No 3 or No 4 cylinder please.
Not Z900 please.
Regards
Steve.
Not Z900 please.
Regards
Steve.
wilsonsjw11
Re: Genuine Z1 exhaust clamp for No3 cylinder.
Thanks for the link.
Some pattern, many Z900 and a full set.
Only looking for one.
Regards
Steve
Regards
Steve
wilsonsjw11
Now sorted.
Regards
Steve
Regards
Steve
wilsonsjw11
Still looking for this item after being let down by DK.
When the clamp that I ordered for No3 turned up it was indeed the correct item but someone in its history had ground off some of the fins so it fitted cylinder No4!!
Regards
Steve.
Regards
Steve.
Steve,
Have you tried John Browse at Wrexham 01978 355556?
Dave
Dave
wilsonsjw11 wrote:As the title says, genuine Z1 exhaust clamp for No 3 cylinder please.
Not Z900 please.
Regards
Steve.
excuse the ignorance but whats the difference between z1 and z900.
I've got a few but couldn't tell which is which
wilsonsjw11
The Z1 item has less "meat" round the 2 fixing holes which caused them to split, this prompted Kawasaki to produce a more robust unit for the models going forward.
The clamp for cylinders 3 + 4 should be the same.
Regards
Steve
Regards
Steve
- sockpuppet
Hi
Are any of these the right thing ?
I think i got them on an old Devil exhaust i got years ago, but haven`t a clue what they`re off .
I only just noticed they are different ! ( can anyone id what they are please)
Regards
Mick
Regards
Mick
wilsonsjw11
What bike have they been fitted to?
Top photo bottom image looks right but not sure if the holes are 8mm when they should be 6mm.
Regards
Steve.
Regards
Steve.
The one on the right looks 6 mill early z1 one on the left looks 8 mill later z1
wilsonsjw11
No Z1s had 8mm exhaust studs
- sockpuppet
Hi
I have measured the holes ,the one on the left is 9mm at the front stepped to 12mm at the back .
The holes in the one on the right are 8mm all the way through - i can`t tell if they`ve been drilled out or not.
They were both on the same exhaust system that i got off Ebay about 10-15 years ago ,
Sorry i have no idea what bike it was on previousely .
Mick
Mick
