Engine head and crankcase buffing/cleaning
Oggers
#1 PostAuthor: Oggers » Thu Jun 25, 2020 10:36 am
Chaps
Bike finally in bits, engine out of the frame looking bereft. It is actually in good condition, and I want to preserve the origianality yet at the same time clean it up a bit to a kind of factory fresh standard, but not to overdo things. Not really a fan of blasting, and don't really want to lug a heavy engine about either. As such, I was thinking of giving it a jet wash with Gunk, but then several suggestions for the finned head, block and crankcase.
Remove all outer covers for mild polishing.
Then for the remainder
Had good previous success with Tcut and fine wire wool. Labourios though....
Tried a soft brass wire brush - seemed to work well and brought up a nice, less porous looking finish on the metal.
Not tried a soft rotary brass wire brush on the end of a drill - possible?
The big problem is the head fins and how to clean inside them - long soft wire brass brush perhaps
or a combination of all of the above
Thoughts very welcome on how to proceed, or other tried and tested methods
1946 Ariel VB600, 1966 Triumph Bonneville, 1975 400/4, 1979 Z650
Re: Engine head and crankcase buffing/cleaning
#2 PostAuthor: chrisNI » Thu Jun 25, 2020 11:15 pm
:D :D
compo z1r
#3 PostAuthor: compo z1r » Fri Jun 26, 2020 8:03 am
chrisNI wrote:
:D :D
Or pay someone else to do it :sad
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
