Wiring loom question
brian 450
#1 PostAuthor: brian 450 » Sun Jun 28, 2020 8:51 am
Hi,my Z hasn’t been used for 3years, I am fitting a new loom. My question is what plugs into the second plug from left next to the green one behind the LH side panel.
Re: Wiring loom question
#2 PostAuthor: z1bman » Sun Jun 28, 2020 12:57 pm
if you mean the white connector its the rectifier
brian 450
#3 PostAuthor: brian 450 » Sun Jun 28, 2020 1:11 pm
My rectifier has a green plug
Big Fluff
#4 PostAuthor: Big Fluff » Sun Jun 28, 2020 1:27 pm
brian 450 wrote:My rectifier has a green plug
Wrong... that's the regulator.
WHITE: RECTIFIER
GREEN: REGULATOR
BLUE: ALTERNATOR
BROWN: MAIN HARNESS
brian 450
#5 PostAuthor: brian 450 » Sun Jun 28, 2020 3:36 pm
The REGULATOR is a replacement from power. Not got a rectifier on bike for some reason.
brian 450
#6 PostAuthor: brian 450 » Sun Jun 28, 2020 3:53 pm
Just checked it and the regulator I have. there are 3 yellow 1 brown 1 black and 1 white coming from it. So does it plug in the white or green? The plug on it is green
z2.john
#7 PostAuthor: z2.john » Sun Jun 28, 2020 5:52 pm
Without pictures I cannot say for sure but I suspect you have the combine rec/reg unit in which case you use the green connector and leave the white one unused.
brian 450
#8 PostAuthor: brian 450 » Sun Jun 28, 2020 5:55 pm
Yes that’s what I am thinking. Thanks for help guys
CAT3
#9 PostAuthor: CAT3 » Sun Jun 28, 2020 8:18 pm
Maybe it's a combined rectifier/regulator, green plug goes to the green socket, black wire is the earth & the white wire is the charging wire for the battery. It's possible if you leave the white wire disconnected the battery will go flat ?
