Unitrac starter motor
ANGRY
#1 PostAuthor: ANGRY » Sun Jun 28, 2020 11:23 am
Hi Has anybody got a starter motor for a unitrac 1100 Please.
KWACKERZ1
Re: Unitrac starter motor
#2 PostAuthor: KWACKERZ1 » Mon Jun 29, 2020 3:54 pm
cb900 H**** ones will work and are an upgrade. but i believe you have to rotate the case.
ANGRY
#3 PostAuthor: ANGRY » Mon Jun 29, 2020 4:22 pm
Thanks i know i have been trying to get one there arnt mny about only in America and you get stung for Import tax and vat
rickm
#4 PostAuthor: rickm » Mon Jun 29, 2020 5:23 pm
KWACKERZ1 wrote:cb900 H**** ones will work and are an upgrade. but i believe you have to rotate the case.
Just curious as I may need one myself, which model year CB900 will fit a gpz / J motor ?
H2B GPZ900R
Adrianbrooksbank
#5 PostAuthor: Adrianbrooksbank » Wed Jul 01, 2020 7:03 pm
Hodna cb750 and cb900 1980-1984 are starter motors to use just the starter cable is on the side and you can file down after starter cable attached,used on my z1170R years ago with good results. Some times replacing brushes on starter motors can give good results,parts availability much better than when most Zeus where new,had them when new and still have similar now,hope this helps
Mr Bump
#6 PostAuthor: Mr Bump » Thu Jul 02, 2020 1:38 pm
Got a z1100 st I'm breaking at the mo.. if it's the same part no. I'll whip it off and test it.
Lemmy
Mr Bump
#7 PostAuthor: Mr Bump » Thu Jul 02, 2020 6:47 pm
Mr Bump wrote:Got a z1100 st I'm breaking at the mo.. if it's the same part no. I'll whip it off and test it.
Just looked it up on cmsnl ... comes up as part no 2116-31143 fits z1100 shaft, z1000j and gpz1100a1 & a2.
£65 delivered. If you want it I'll whip it off the bike and bench test it.
Olly
Lemmy
Hobbo
International Rep
#8 PostAuthor: Hobbo » Sun Jul 05, 2020 3:49 pm
Guys
There is 2 in the estate of Ginger bear I will.photo later
Not sure of fitment
Phil
International Rep
