Hi,
Looking for some advice on the best way for a repair to a damaged cylinder block. (see photos below)
The block is a spare I've had for some years and was getting prepared for a re-bore etc. The front cam guide needed to be removed, the screw was tight so had to use an ezee out, when the screw came out it was covered with old sealant/glue, a close inspection of the boss in the cylinder block showed that it was badly cracked. Any advice on the best way to get a repair done?
Thanks for looking.
Cylinder Block Damage
