73 Wheels/Rims
Curlywurly
73 Wheels/Rims
Hi All
Looking for Front and Rear Wheels/Rims Takasago stamped 3C or 3D, bit of a longshot I know, but thought I would ask on here as you never know !
Thanks Shaun
Thanks Shaun
nick sanderson
Re: 73 Wheels/Rims
I've been looking for a 3c rear for a long time .
Good luck if you find 2 i'll take one
nick sanderson
Re: 73 Wheels/Rims
I keep searching for 3c or close rear rim or wheel ,anyone got one before I take a desperate plunge.
shorturl.at/hHJV2
shorturl.at/hHJV2
Re: 73 Wheels/Rims
That link sent my Kaspersky AV into Armageddon Mode
Z1-B, 360bhp ZX1000NGF
nick sanderson
Re: 73 Wheels/Rims
nick sanderson wrote:Oop's try this
https://www.ebay.co.uk/itm/1972-76-kawa ... 4650127673
Suspect its a H2 wheel as I can only see 1 hole in the rim ,should be 3.
Re: 73 Wheels/Rims
This is an H2 item. It will fit Z1 but is wrong if you are looking for originality.
Re: 73 Wheels/Rims
marmck wrote:nick sanderson wrote:Oop's try this
You're eyesight is better than mine. I can't see any valve holes at all.
I guess it's one of those special solid-rubber types
Re: 73 Wheels/Rims
steve452 wrote:You're eyesight is better than mine. I can't see any valve holes at all.
Re: 73 Wheels/Rims
Press control & scroll with your mouse wheel ,simples .
Re: 73 Wheels/Rims
Tried that but my optician said it still hadn't improved my eyesight.
Or did you mean to use it over the image?
scott reid
Re: 73 Wheels/Rims
Hi, what does the 3c signify? I have a 3G 303 rear, I'm just wondering what the difference is.
Scott
Scott
Re: 73 Wheels/Rims
C=March G= July - https://www.freewebs.com/750rs/datecodes.htm
Re: 73 Wheels/Rims
scott reid wrote:Hi, what does the 3c signify? I have a 3G 303 rear, I'm just wondering what the difference is.
Scott
It refers to the date of build as in "197x" where x=numeric for the year (ie in this case 1973) and the digit refers to the month starting from A=Jan, B=Feb and so on. So your 3G is a July 1973 build. Nice and early!
Re: 73 Wheels/Rims
Sorry marmck, didn't spot your reply before I posted my tome
